How to Adjust Resistance in Voltmeters and Ammeters for Accurate Measurements
In summary, the voltmeter can measure a larger potential difference by increasing the resistance, changing the shunt in an ammeter to allow for larger current measurements, or by connecting an ohmmeter to an adjustable resistor and an ideal ammeter. A resistance of 6000 ohms is required for half scale, 18000 ohms is required for quarter scale, and 2000 ohms is required for three quarter scale.
scorpa
367
Hello!
I'm doing some questions in my book and have hit a problem area.
#1) How would you change the resistance of a voltmeter to allow the voltmeter to measure a larger potential difference?
I was thinking that you would have to increase the resistance is order to measure a larger potential difference but I am not quite sure.
#2) How would you change the shunt in an ammeter to allow the ammerter to measure a larger current?
For this one I don't even know what a shunt is, my textbook hasn't really dealt with it at all. I'm not really sure what to say about it.
#3) An ohmmeter is made by connecting a 6.0V battery in series with an adjustable resistor and an ideal ammeter. The ammeter deflects full scale witha current of 1.0mA. The two leads are touched together and the resistance is adjusted so 1.0mA current flows.
a) What is the resistance of the adjustable resistor?
V/I = R 6.0V/1x10^-3A = 6000 ohms
b) The leads are now connected to an unknown resistance. What external resistance would produce a reading of 0.50 mA, half full scale?
The answer is also 6000 ohms but I'm not sure why
c) What external resistance would produce a reading of 0.25 mA, quarter scale?
The answer is 18000 ohms but I'm not sure why
d) What external resistance would produce a reading of 0.75mA, three quarter full scale?
The answer is 2000 ohms but once again I am not sure why.
I'm sure that these questions are absolutely stupid, but I really can't get my mind around them. I've done all the hard ones without a problem now I get to these and I'm stuck :rolleyes: Any help you can give I would really appreciate! Thanks!
scorpa said:
Hello!
Thanks!
#1) Think about how a voltmeter works. How do you hook one up to measure a voltage? (you might draw a simple circuit with a battery and a load resistance and also draw how you hook up your voltmeter). How many paths can current go in your simple circuit?
#2 Shunt is to create an additional path to divert the flow of something.
If you had a river next to a stream, by opening up a channel between the river and stream, some of the river water will be diverted to the stream while the rest of the water will continue in its original path. Depending on how large your channel was, this will impact, how much water is diverted over time.
3a) What is the resistance of the adjustable resistor?
V/I = R 6.0V/1x10^-3A = 6000 ohms assuming you know what characteristics an ideal ammeter has, you are correct
3b) The leads are now connected to an unknown resistance. What external resistance would produce a reading of 0.50 mA, half full scale?
A clear diagram of how your circuit is hooked up is important.
It would be useful to do that and post it here. We can then see how you are interpreting the information.
(Hint: you could model your Ammeter as a resistor in parallel with a voltmeter).
You may also want to review Kirchoff's Current Law. Once you understand that, answering (b), (c) and (d) will be very clear.
3c) What external resistance would produce a reading of 0.25 mA, quarter scale?
3d) What external resistance would produce a reading of 0.75mA, three quarter full scale?
OK thanks, I did figure the questions out eventually, I can't believe how stupid I was. I was going to post a diagram of the question but I don't know how to put it onto the forums. Turns out there was bad information in the question, but that didn't make the teacher omit it. Thanks again.
1. What is the difference between series and parallel circuits?
In a series circuit, the components are connected in a single loop with the same current flowing through each component. In a parallel circuit, the components are connected in multiple branches with the same voltage applied to each branch. This results in different currents flowing through each component.
2. How do I calculate the total resistance in a series or parallel circuit?
In a series circuit, the total resistance is equal to the sum of the individual resistances. In a parallel circuit, the reciprocal of the total resistance is equal to the sum of the reciprocals of each individual resistance.
3. What is Ohm's law and how is it used in circuit calculations?
Ohm's law states that the current through a conductor is directly proportional to the voltage and inversely proportional to the resistance. This means that if the voltage is increased, the current will also increase, and if the resistance is increased, the current will decrease. Ohm's law is commonly used to calculate the current, voltage, or resistance in a circuit.
4. How do capacitors and inductors affect the behavior of a circuit?
Capacitors store and release electrical energy, while inductors store and release magnetic energy. In a DC circuit, capacitors act as open circuits and inductors act as short circuits. In an AC circuit, capacitors and inductors can change the phase relationship between voltage and current, and can also filter certain frequencies.
5. What is the difference between AC and DC circuits?
AC (alternating current) circuits have a continuously changing voltage and current, while DC (direct current) circuits have a constant voltage and current. AC circuits are used for long distance power transmission, while DC circuits are used for electronic devices. AC circuits can also use transformers to change the voltage, while DC circuits cannot.
