Circuits physics question
  1. Jun 5, 2009 #1
    A metal rod of mass 0.22 kg lies across two parallel conducting rails that are a distance of 0.52 m apart on a tabletop, as shown in the top view above. A 3.0 W resistor is connected across the left ends of the rails. The rod and rails have negligible resistance but significant friction with a coefficient of kinetic friction of 0.20. There is a magnetic field of 0.80 T perpendicular to the plane of the tabletop. A string pulls the metal rod to the right with a constant speed of 1.8 m/s.
    (a) Calculate the magnitude of the current induced in the loop formed by the rod, the rails, and the resistor.
    (b) Calculate the magnitude of the force required to pull the rod to the right with constant speed.
    (c) Calculate the energy dissipated in the resistor in 2.0 s.
    (d) Calculate the work done by the string pulling the rod in 2.0 s.
    (e) Compare your answers to parts (c) and (d). Provide a physical explanation for why they are equal or unequal.
    Page 10 on this document: http://apcentral.collegeboard.com/apc/public/repository/ap09_frq_physics_b.pdf
    2. Relevant equations
    I =V/R
    3. The attempt at a solution
    A) I = V/R?
    I'm a bit confused... there seems to be an overload of information on this problem. I would appreciate some direction.
  3. Jun 5, 2009 #2
    LowlyPion
    Re: Circuits
    Won't the induced current be proportional to the rate of the change of flux in a loop of wire? Consider then the rate of change of the area.
  4. Jun 5, 2009 #3
    Re: Circuits
    Oh gosh... I do recall doing something like this. I'll try to find my notes...
    Ok, I found two things that are potentially relevant. I have magnetic flux (BAcos[tex]\theta[/tex]) and mortional emf (Blv).
    Are any of these remotely correct?
  5. Jun 5, 2009 #4
    Re: Circuits
    I am not an expert but personally, I would look into Ampere's law, Faraday's law and biot-savart law (not sure on the latter).
  6. Jun 6, 2009 #5
    LowlyPion
    Re: Circuits
    Yeah, well what is the rate of change of the area of the loop? A = w*Δx
    Won't the voltage be something like
    V = Δ(B*A)/Δt
    With B constant and ΔA/Δt = w*Δx/Δt = w*v
    then won't
    Voltage = B*w*v
    The resistance is fixed at 3Ω.
  7. Jun 7, 2009 #6
    Re: Circuits
    Then apply I = V/R? With R = 3 and V = Bwv? Or am i interpreting this wrong?
  8. Jun 9, 2009 #7
    Re: Circuits
    Oh, got it! Would someone mind helping me with (b), then?
    Doesn't this just deal with the velocity, (1.8 m/s) and the coefficient of kinetic friction (0.20)?
    Edit: Rather, is it Fs = FB + Ff?
    Edit2: But how would you find the force related to these?
  9. Jun 9, 2009 #8
    LowlyPion
    Re: Circuits
    Well, I would suggest that you of course have the frictional component, but then you also have the energy that goes into the resistor which is I2R.
  10. Jun 9, 2009 #9
    ideasrule
    Re: Circuits
    Consider what is happening: the rod is moving, which changes the magnetic flux across the circuit, which induces a voltage. This voltage causes a current. The magnetic field then imposes a force on this current that opposes the motion of the rod. Calculate this force, calculate the force of friction, add the two together and you'll get the total force needed to pull the rod.
  11. Jun 10, 2009 #10
    Re: Circuits
    Would the magnitude of the magnetic force be: F = qvBsin[tex]\theta[/tex]?
    And I know one equation that would apply for the magnitude of the force of kinetic friction: fk = [tex]\mu[/tex]kn
    But this equation doesn't seem to give me enough information to solve for the force of kinetic friction... Any help?
  12. Jun 10, 2009 #11
    LowlyPion
    Re: Circuits
    Almost. Consider the form of the magnetic force equation that matches the geometry of the situation you have in the problem.
    F = I*B*w*sinθ
    where w is the length of the rod across the tracks. (Sinθ of course is 1 for this set up.)
    So multiplying F*v = B*v*w*I = V*I
    Force times velocity is power. Power is the Voltage found before times current which can also be expressed as I2R
  13. Jun 10, 2009 #12
    Re: Circuits
    Got it! Thank you for your help!
  14. Jun 10, 2009 #13
    Redbelly98
    Staff Emeritus
    Re: Circuits
    FYI, something to look for in the future: these introductory magnetism problems generally involve either current-carrying wires, or a charge q moving at velocity v. Since this problem involves current in a wire, you'd want to use an equation that contains I rather than one with q and v.
  15. Jun 10, 2009 #14
    Re: Circuits
    Thanks for the advice, Redbelly98! I appreciate it. :smile:
Similar Discussions: Circuits physics question
Loading...
