Homework Help: Circuits Problem
  1. Jul 30, 2011 #1
    A circuit with a resistor, capacitor, and inductor all connected in parallel with resistance = 5000 ohm, inductance = 1.25H and capacitance = 8nF, find the voltage across the components.
    2. Relevant equations
    v = L*di/dt, i = C*dv/dt, v = iR
    3. The attempt at a solution
    I'm not sure what to do, I tried both node-voltage and mesh current but can't get at a solution
  3. Jul 30, 2011 #2
    tiny-tim
    Hi Red_CCF! :smile:
    Don't we need some more information? :confused:
    What is the power supply (and if it's AC, what is the frequency)?
  4. Jul 30, 2011 #3
    Hi
    Thanks for the response. I uploaded the problem with the drawing of the circuit. They just drew the three components connected in parallel, defined an unknown voltage across them and asked for the voltage response.
  5. Jul 30, 2011 #4
    gneill
    Staff: Mentor
    Presumably the "response" required will be that due to a unit step or impulse applied to the circuit.
    You should investigate the concept of damping for oscillations. You should be able to find the expression for the damping factor for the parallel RLC circuit and determine whether this circuit is underdamped, critically damped, or overdamped.
  6. Jul 31, 2011 #5
    Thanks very much. I completely forgot about the formula for RLC circuits
Loading...
