1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Circuits: Three-Wire Single Phase System
  1. Jul 25, 2007 #1
    An inefficient three-wire single-phase system has source voltage of Van=Vnb=720/_0 degrees V, line resistance RaA=RbB=1 ohm, with RnN=10 ohm, and loads ZAN=10+j3 ohm, ZNB=8+j2 ohm, and ZAB=18+j0 ohm. Find a) IaA b) InN, c) Pwiring,total d) Pgen,total
    2. Relevant equations
    I used mesh analaysis to find the current around each loop
    3. The attempt at a solution
    When solving for the current around each loop using mesh analysis I ended up getting 720 Arms for I1, I2, and I3, which is the incorrect answer (the correct answer for IaA is 126.06 @ -6.479 degree A. And through my calculation the InN will have zero current but that can't be true since this system is an inefficient system. It could be that I set up my mesh equations incorrectly but I can't see where I did wrong though.
    The attempt for a solution is added in as an attatchment.
Draft saved Draft deleted
