Circular Motion: Solving for Velocity using Vector Cross Product
In summary: I can't keep up.If I can just sneak in for a moment,... the problem statement says that there are 1.4 revolutions per second, not 1... sorry, I can't keep up.Yes, the problem statement says 1.4 revolutions per second.
connorc234
http://i.imgur.com/Nbg3Nrc.jpg
pic of question
v = wr, s=rtheta t=1/f etc
i did a, got 504 radpersec and then did b, r = 1.3sin40 i - 1.3cos40 j + 0 k
but I'm not sure if I'm doing it right. can anyone help me and point me in the right direction?
thanks,
Connor
connorc234 said:
http://i.imgur.com/oIKdE9U.jpg
pic of question
thanks,
Connor
Welcome to the PF.
The top of your image is cut off, so we don't see the whole figure.
Also, could you show the steps that you used to get to your answers? That will save a lot of time in helping you out. :smile:
Welcome to the PF.
sorry, changed it to a better picture.
for a. T = 1/1.4 where T is the period
t = (40/360)(1/1.4) to find the time taken for the mass to turn through 40 degrees
=(1/12.6)
w = dtheta/dt = 40/(1/12.6)
w = (40)(12.6) = 504 radpersec
b. used trigonometry with theta = 40 and hypotenuse = 1.3 to find x and y with the axel centre being the origin
hence 1.3sin40 for x and (-)1.3cos40 for y
Your answer for (b) looks right, but (a) doesn't look right.
There are 2π radians in a circle, and the rod rotates through a full circle every 1.4 seconds. What ω does that result in?
2π/1.4
something i don't understand is that the question is asking for vectors, so how would i put ω = 2π/1.4 in vector form?
should I use my answer for b in the future questions, since it's continuously asking for vectors?
A vector definition of ω involves the cross product:
https://en.wikipedia.org/wiki/Angular_velocity
And the direction of the vector ω is determined by the right hand rule for that cross product. Does that make sense? Have you learned about the vector cross product yet?
i've learned the right hand rule yeah, don't think I've seen the cross product before. but i don't know if they just want 2pi/1.4 or if they want me to split it into i's j's and k's somehow. and if so i have no idea how to do that. the fact that they ask for a position vector after that question confuses me too if they do indeed want a vector for the angular velocity
From the right hand rule, since ω ~ r X v, the direction of ω is the direction your right thumb points when you point your right fingers in the direction of r and curl them towards v. What is that vector direction? :smile:
that's the k or z direction right?
so the vector would be 0i + 0j + 2pi/1.4 k ?
If I can just sneak in for a moment,... the problem statement says that there are 1.4 revolutions per second, not 1 revolution per 1.4 seconds. I thought I'd point that out before all the calculations were done :smile:
Likes berkeman
Oops, thanks! :smile:
Correct, after you apply gneill's fix to the value for ω :smile:
vbx
problem now though...
using the 2 answers for a and b with the equation v=wr in vector form, gives me 0i + 0j + 0k...? is this meant to happen?
connorc234 said:
vbxproblem now though...
No. You are going to need to use the vector cross product, or a simplified version if your textbook has it. As shown at this textbook page:
https://books.google.com/books?id=g...QIVT8pjCh2Owgcq#v=onepage&q=v = w x r&f=false
v = r X ω
So you get the vector v using the right hand rule with r and ω. With the problem as drawn, the velocity v is always perpendicular to r, so that simplifies the cross product. What does your textbook list as relevant vector equations for problems like this? You only listed scalar equations...
https://books.google.com/books?id=gJA2oahuPSMC&pg=PA48&lpg=PA48&dq=v+=+w+x+r&source=bl&ots=SRNGSMXm_F&sig=aR2L-m4L_YkUZJYRmKyL7gBA01o&hl=en&sa=X&ved=0CFkQ6AEwCGoVChMIjq-LxOOByQIVT8pjCh2Owgcq#v=onepage&q=v = w x r&f=false
v = r X ω
http://i.imgur.com/VL6r6Oo.jpg
i have this which i think might be relevant. does this mean i can just use v=wr as normal?
Yes, and the direction is the vector shown in the diagram. You can figure out the x and y components given the angles...
ok thanks.
one last question. should i use the position vector for r (1.3sin40 i -1.3cos40 j) or its modulus?
Depends. If you were doing the vector cross product, then you would use the components. Since you are using the simplified form, you need the magnitude of r and the magnitude of ω multiplied together. You get the magnitude of v with that multiplication, and then you convert it into the vector components of v. Makes sense?
yeha i got it now thanks a lot man really appreciate it.
Likes berkeman
1. What is circular motion?
Circular motion is a type of motion in which an object follows a circular path around a fixed point, known as the center of rotation. The object moves at a constant speed, but its direction is constantly changing, resulting in a circular path.
2. What is the difference between uniform and non-uniform circular motion?
In uniform circular motion, the speed of the object remains constant while it moves in a circular path. In non-uniform circular motion, the speed of the object changes at different points along the circular path.
3. How is circular motion related to centripetal force?
Centripetal force is the force that keeps an object moving in a circular path. In circular motion, the centripetal force is directed towards the center of the circle and is responsible for changing the direction of the object's velocity.
4. What are some real-life examples of circular motion?
Some examples of circular motion in everyday life include the Earth's orbit around the Sun, a car going around a roundabout, and a ball being swung around on a string.
5. How is circular motion different from rotational motion?
Circular motion involves an object moving in a circular path, while rotational motion involves an object spinning about its own axis. In circular motion, the object moves in a constant speed and direction, while in rotational motion, the object's speed and direction can change.
10K
