azncocoluver
- 22
A 0.55 kg stone attached to a string is whirled in a horizontal circle of radius 19 cm as in the figure below. The string makes an angle of 35° with the vertical.
That's not the way it works here at Physics Forums.azncocoluver said:No clue lol.. can you show me the solution because I've never done a problem like this before. I kind of learn better when I see an approach first :]
Homework Help:
You MUST show that you have attempted to answer your question in order to receive help. You MUST make use of the homework template, which automatically appears when a new topic is created in the homework help forums. Once your question or problem has been responded to, do not go back and delete (or edit) your original post.
<snip>
On helping with questions: Any and all assistance given to homework assignments or textbook style exercises should be given only after the questioner has shown some effort in solving the problem. If no attempt is made then the questioner should be asked to provide one before any assistance is given. Under no circumstances should complete solutions be provided to a questioner, whether or not an attempt has been made.
Circular motion speed refers to the speed at which an object moves along a circular path. It is the distance travelled by the object divided by the time it takes to complete one full revolution.
Circular motion speed can be calculated by dividing the circumference of the circle (2Πr) by the time it takes to complete one full revolution (T). The formula is v = 2Πr / T.
Circular motion speed and tangential speed are often used interchangeably, but they are slightly different. Circular motion speed refers to the speed along the circular path, while tangential speed refers to the speed in a straight line tangent to the circle at a specific point.
The radius of a circle directly affects the circular motion speed. The larger the radius, the greater the distance the object must travel in one full revolution, resulting in a higher speed. Conversely, a smaller radius will result in a lower circular motion speed.
Yes, circular motion speed can change. It can change if the radius of the circle changes, or if the object speeds up or slows down. It can also change if the mass of the object changes, as this affects the centripetal force required for circular motion.
