Exploring Circular Motion: A Bead on a Ring
In summary, a bead of mass m moves on a smooth circular ring of radius a and its speed at the highest point of its path is v and at the lowest point is 7v. By using conservation of energy, we can find that v = √(ag/12). To find the reaction of the ring on the bead at point A, we use the equation ΣF = ma and substitute in the values to get R = 13mg/12.
RoryP
75
Circular Motion!
A bead of mass m moves on a smooth circular ring of radius a which is fixed in a vertical plane. Its speed at A, the highest point of its path, is v and its speed at B, the lowest part of its path, is 7v.
a) show that v= [square root](ag/12)
b) find the reaction of the ring on the bead, in terms of m and g, when the bead is at A
F=mv 2 /r
EK= 1/2mv2
EP= mgh
a)
At point A
EK= 1/2mv2
EP= 2mga
At point B
GPE= 0
EK= 1/2m(7v)2
(Conservation of energy)
1/2m(7v)2 = 1/2mv2 + 2mga
(m's cancel)(multiply through by 2)
49v2= v2 + 4ag
48v2= 4ag
v2= 4ag/48 = ag/12
v=[square root](ag/12)
That I am fine with, its part b which confuses me!
b)
mv2/r + mg = R
(r=a)(v2= ag/12)
mag/12a + mg= R
mg/12 + mg= R
R=13mg/12
But that isn't correct! any help would be greatly appreciated =]
Is there a sketch to the problem?
I think R= mgcos(P) +...
while we need to find angle P, or I'm imaging the case all wrong.
but I'm not sure, If You could show me a sketch I could be greater help.
RoryP said:
b)
mv2/r + mg = R
Careful with signs. I'll use positive = up and negative = down:
ΣF = ma
-mg + R = -mv²/a
(and so on..)
is that becuase v^2/r = acceleration
ahhh that would give you an answer of 11mg/12 which is the correct answer! Thanks for your help =]
1. What is circular motion?
Circular motion is the movement of an object along a circular path, where the object maintains a constant distance from a fixed point called the center of the circle.
2. How is circular motion different from linear motion?
Circular motion involves a change in direction, while linear motion involves a change in distance. In circular motion, the object is constantly changing direction due to the curvature of the path, while in linear motion, the object moves along a straight line.
3. What is the role of centripetal force in circular motion?
Centripetal force is the force that keeps an object moving in a circular path. It acts towards the center of the circle and is necessary to prevent the object from flying off in a tangent.
4. What factors affect the speed of an object in circular motion?
The speed of an object in circular motion is affected by the radius of the circle, the mass of the object, and the strength of the centripetal force acting on the object.
5. How is circular motion used in real life?
Circular motion is used in many real-life applications, such as amusement park rides, car tires rotating while driving, and the movement of planets around the sun. It is also used in various machinery, such as turbines and centrifuges, to produce rotational motion.
