Circular motion
  • Thread starter john_f2004
An exhaust fan rotates at 9.0 x 10^2 revolutions per minute. Find the acceleration of a point on a blade at a distance of 25cm from the axis of rotation.
I don't know where to begin. Can someone help?
Answers and Replies
dextercioby
Insights Author
13,002
550
How about:what theory would have to use to get it solved...?Formulas and a reasoning for using them...
Open your book.
Daniel.
Ok I think the ? has to do with uniform circular motion. The only equation I am given is a (sub) c = v^2 divided by r
A (sub) c = centripetal acceleration
v = velocity
r = radius
dextercioby
Insights Author
13,002
550
[itex] a_{cp}=\omega^{2} r [/itex] is the formula that u need.
U have been give the frequency.Find the angular velocity "omega"...
Daniel.
isnt that the same formula i just gave you?
dextercioby
Insights Author
13,002
550
Not really.There's a close connection between the 2,though.So do it.
Daniel.
that is the problem I don't know how
dextercioby
Insights Author
13,002
550
[tex] a_{cp}=(2\pi\nu)^{2}r [/tex]
U know "r" and u know "nu",now find the acceleration.Convert from revs/min to Hz...
Daniel.
the question has nothing to do with frequency
dextercioby
Insights Author
13,002
550
If you don't see it,that's bad.
"rotates at 9.0 x 10^2 revolutions per minute"...what does that mean?
Daniel.
the answer i am supposed to get has nothing to do with frequency. all i need to know is the acceleration. no where in our notes and in our class did we talk about frequency.
dextercioby
Insights Author
13,002
550
Incidentally,in this problem you are given the frequency & the distance between the point & the center of the circle.
I can't do anything more.I've already told u what to do...
Daniel.
Johnf2004,
In the given quetion you are given the frequency,f i.e. number of revolutions per minute. You can convert this into time period, T using:
T = 2*pi/f
Now use [tex] v = \frac{2 \pi r}{T} [/tex]
as for an object moving with constant speed on a circular path, v = s/t
Here, the distance,s is the circumference(2*pi*r) traversed in time t. But then t, the time is also equal to time taken for one complete revolution, hence equal to T.
acceleration = (v^2)/r
What dextercioby has explained is same , he started with [tex]\omega[/tex], the angular velocity
Related Threads on Circular motion
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
