Max Distance Block Can Be Placed Before Sliding Off Turntable
In summary, the coefficient of friction between a certain brass block and a large revolving turntable is µ = 0.09. If the turntable rotates at a constant rate of 33.33 rev/min, the brass block can be placed as far from the axis of rotation as desired before it slides off the turntable.
huskydc
78
The coefficient of friction between a certain brass block and a large revolving turntable is µ = 0.09. How far from the axis of rotation can the block be placed before it slides off the turntable if the turntable rotates at a constant rate of 33 1/3 rev/min (so that it requires time T = 60/33.33 seconds to complete one revolution) ?
V(tangential) = 2pi R / T
i'm not sure if 33.33 rev/min is the V, but i tried plugging in the respective numbers and solve for R, didnt really make much sense.
Draw free body diagram on the block, and use Newton's 2nd Law, also because the velocity vector has constant magnitude it means the tangential acceleration is 0, therefore there's only radial (normal) acceleration. Use this to solve for the radius.
well, i drew a FBD on the block.
and i have :
f = ma
N=mg
from that i solve for a, which = .8829
but I'm still confused as to what that 33.333 rev/min
That's just the speed.
It's simply:
[tex] F_{friction} = m \frac{v^2}{R} [/tex]
already tried, didnt work either.
i tried:
F = m (v^2/R)
like you said, V = 33.333
mu g = (v^2 / R) and solve for R this way, didn't work. I've been told that 33.333 is not just V. and if it is, then what's the T for?
You need to have common units!, convert rev/min to m/s!
ok, maybe I'm just dumb with this. (as you can tell physics not my cup of tea)
converted rev/min to rad/s.
i did this:
33.333 rev / min x (1 min/60 sec) x (2pi rad/ 1 rev) = 3.49 rad/s
with mu g = (v^2 / R) , R= (v^2)/mu g
am i doing something wrong that i just don't see?
Yes, that's ok. Now i am little confused about the statement so that it requires time T = 60/33.33 seconds to complete one revolution.
Is that how the book states it, it looks to me you would need to use.
[tex] F_{frictionn} = m \frac{4 \pi^{2} R}{T^{2}} [/tex]
where T is the time for one revolution or the period T, but what you did above, should have worked just the same.
yes, cyclovenom, that one worked. but how did that equation come about?
Thanks so much! (physics is so hard...well for me it is...)
Sorry, on the above i meant rev/min to m/s, my bad :redface:
it came from
[tex] v = \frac{2 \pi R}{T} [/tex]
substitute in
[tex] a_{c} = \frac{v^2}{R} = \frac{4 \pi^{2} R}{T^2} [/tex]
What is the "Max Distance Block Can Be Placed Before Sliding Off Turntable"?
The "Max Distance Block Can Be Placed Before Sliding Off Turntable" refers to the maximum distance a block can be placed on a turntable before it slides off due to the centrifugal force caused by the rotation of the turntable.
Why is it important to know the "Max Distance Block Can Be Placed Before Sliding Off Turntable"?
It is important to know the "Max Distance Block Can Be Placed Before Sliding Off Turntable" in order to ensure the stability and safety of the turntable and any objects placed on it. If the distance is exceeded, the block may slide off and cause damage or injury.
How is the "Max Distance Block Can Be Placed Before Sliding Off Turntable" calculated?
The "Max Distance Block Can Be Placed Before Sliding Off Turntable" is calculated by taking into consideration the speed of rotation of the turntable, the weight and dimensions of the block, and the coefficient of friction between the block and the turntable surface.
Can the "Max Distance Block Can Be Placed Before Sliding Off Turntable" be increased?
Yes, the "Max Distance Block Can Be Placed Before Sliding Off Turntable" can be increased by either reducing the speed of rotation of the turntable, increasing the coefficient of friction between the block and the turntable surface, or by using a lighter and more compact block.
Are there any safety precautions to take into consideration when placing blocks on a turntable?
Yes, it is important to always be aware of the "Max Distance Block Can Be Placed Before Sliding Off Turntable" and to follow the calculations and recommendations in order to prevent accidents or damage to the turntable and objects on it. It is also important to secure the turntable and any objects placed on it to a stable surface to prevent movement or tipping.
