Circular movement
  • Thread starter brad sue
brad sue
281
hi ,
I have a problem about vector coordinates. this is the problem.
We have a 2-dimension space [x(unit vector i) and y( unit vector j)].
I have a circle of center 0 (0,0) and a point P such that OP = r.
Vector OP and the x-axis have an angle of θ .
there is a unit vector ir , with the same direction with OP( but starting at P.)
Another unit vector it starts at P , but it is perpendicular to vector ir. ( it 's direction is toward north-west)
Express vector ir as a combination of unit vectors i and j.
Express vector it as a combination of unit vectors i and j.
I found that ir = cos(θ ) i + sin(θ ) j
how to find it ? when I try to compute for it, I found the same as ir, but I am not sure.
Please help
Thank you
Answers and Replies
Doc Al
Mentor
45,450
1,911
Since it is perpendicular to ir, they cannot have the same components. Draw a careful diagram. (I suspect you are mixing up your sines and cosines.)
brad sue
281
OK, I follow your suggestion and now I find:
it= sin(θ )i +cos(θ ) j
I do not know if you did the problem but I believe it is ok now
Doc Al
Mentor
45,450
1,911
It's almost right. To see what's wrong, test if these vectors are perpendicular.
brad sue
281
Doc please I need help for this problem. Someone reply me but I need more information to complete it. It is urgent !
This is a problem I have . But because I cannot include the graph, I try to do via Microsoft Word. I put it as an attachment. I hope that you will understand it.
This is the problem:
Traffic signals are placed along a straight road at positions x = 0 m, x = 600 m, and x = 1200 m (see graph in attachment)). The time intervals during which the signals are green are shown by the thick lines ( in red) in the figure.
(a) Draw the displacement-versus-time curves (fastest and slowest) for a car that passes through all the lights when the car moves with constant speed.
(b) Draw a similar set of lines for a car traveling in the opposite direction.
(c) Assuming that the lights are timed such that a car passes through all lights in the middle of the time interval, what is the speed for which the lights are timed?
(d) What is the fastest constant speed of a car that makes it through all the signals, assuming it arrives at the first light at the optimal moment?
For info.:
The grah is a 2 dimension space with time(s) on horizontal and the position x(m) in vertical.
The interval are put in red and I mentioned the time interval at the end of each line.Please help me with that . I do not understand it
Thank you very much.
Brad
  • graphphys.doc
HallsofIvy
43,021
970
Did you read Doc Al's last post:
"It's almost right. To see what's wrong, test if these vectors are perpendicular."
You had said " ir = cos(θ ) i + sin(θ ) j" and "it= sin(θ)i+ cos(θ)j"
Remember that the dot product of two perpendicular vectors is 0. Here the dot product would be cos(θ)sin(θ)+sin(θ)cos(θ).
Do you see what is wrong? Now look at your picture again.
brad sue
281
I got it
it =-sin(θ)i+ cos(θ)j
Hallsofivy,
Please can take a look at the problem ( about the car and the 3 lights) just above this quote. I do not know if Doc will be available today.
Please give some suggestions.
Thanks
Suggested for: Circular movement
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
