Circular Orbit and Period
  • Thread starter cstout
The Hubble Space Telescope orbits Earth 615 km above Earth's surface. What is the period of the telescope's orbit?
T = 2(pi)r/v
T = 2(pi)(6.37x10^6)/9.8
Answers and Replies
mgb_phys
7,819
Remember the radius of the orbit is measured from the centre of the earth.
Isn't 6.37 × 106 m the radius of the earth, or do I use another measurement.
So, the radius of the orbit is radius of earth? That means the satellite is orbiting in surface, right?
it orbit 615km above the Earths surface
mgb_phys
7,819
The orbital radius is the distance from the centre of the Earth to the satelite.
Hence the radius of the Earth PLUS the altitude = approx 7000km.
Remember to express total distance (Earth's radium + orbital distance) in meters to mantain a coherence among unities.
mgb_phys
7,819
And since you aren't given the speed you also need Kepler's 3rd law to work out the period. Not sure where you got the 9.8 from in your original equation - but it's wrong!
how would you use Kepler's 3rd law in relation to this question though, you aren't given some of the information needed.
Nope - you have everything you need. What information do you think you need for Kepler's 3rd Law that you aren't given?
And by the way, mgb_phys - I'll be cstout was using the value for the approximate acceleration due to gravity at the Earth's surface, i.e. 9.8 m/s^2, which you'd just have to call a pretty bad guess.
mgb_phys
7,819
Remember the simplified form of the law doesn't need the mass of the orbital body
, you can assume that G(M+m) is pretty much equal to GM. Hubble only weighs about 10tons!
Ok, I finally got it, the answer is 1.61 hrs. Thanks for the help
mgb_phys
7,819
That sounds about right, 90 minutes is pretty typical for LEO
Try using this formula: 4(pi)² r³/(M+m)G = P²
Where:
r = radius between the centers of mass of both bodies measured in meters
M = the larger mass in kilograms (5.9742 X 10^24 for the earth)
m = the smaller mass in kilograms (this mass is usually so much smaller than the
larger mass that it can almost always be disregarded)
G = 6.67259 X 10-¹¹
P = the period of orbit in seconds
This formula yields an answer of approx. 5,811 seconds, which is about 96.85 minutes.
I don't think so..
Since the radius,r of the telescope is just about 10% of the radius of the Earth.
Then it can be ignored..
Just use R for the radius of Earth.
Hence, Period of revolution of telescope
= 2Pi Square root R/g
=84.43min
Related Threads on Circular Orbit and Period
  • Last Post
  • Last Post
20K
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
