Calculating Internal Energy Loss from Friction in Satellite Fall
In summary, a 575 kg satellite in a circular orbit at an altitude of 550 km above the Earth's surface eventually falls to the Earth's surface with a speed of 2.10 km/s due to air friction. To calculate the amount of energy transformed to internal energy by means of friction, the initial total mechanical energy of the satellite must be subtracted from the final mechanical energy upon landing, which can be calculated by adding the final kinetic energy and final potential energy. The initial total mechanical energy can be found using the formula for gravitational potential energy, while the final potential energy can be found using the standard expressions for gravitational potential energy between objects. The initial energy can be negative because the standard expressions for gravitational potential energy have infinity as the
brunie
62
A 575 kg satellite is in a circular orbit at an altitude of 550 km above the Earth's surface. Because of air friction, the satellite eventually falls to the Earth's surface, where it hits the ground with a speed of 2.10 km/s. How much energy was transformed to internal energy by means of friction?
ok so
575kg at 550km
falls at 2100 m/s
so the internal energy lost should be the difference between the energy it had in orbit minus the energy it has when it crashes
so for final energy upon crash
Ek = 0.5 * 575 * 2100^2
= 1267875000
so whatever energies it has in orbit (gravitational, potenential, centripital ?) it loses the internal energy due to friction and then ends up with the Ek when it crashes
not too sure if I am attepting this properly, help would be appreciated
When in orbit, the satellite will have some gravitational PE and KE. (You'll need to figure those out!) That will be its initial total mechanical energy. When it reaches the ground it will have some final gravitational PE (figure that out) and some final KE (you are given the speed). The total mechanical energy upon landing (figure that out) will be equal to its initial mechanical energy less the amount of energy transformed to internal energy.
ok so for initial energy i can use the equation for total energy
-GMm/2(Re+h)
-(6.67x10^-11)(5.97x10^24)(575) / 2(6378100 + 550000)
-1.65 x 10^10
so this answer minus the final kinetic and final potential should b the energy loss
= 1.27 x 10^9
but I am not sure what equation to use for the final potential energy at crash
because if the satellite hits the Earth's surface wouldn't potential be zero?
also is it right to have the initial energy negative?
-GMm/2(Re+h)
-1.65 x 10^10
Realize that that equation for total energy is derived by adding PE plus KE. What's the formula for PE by itself? (Look it up if you need to.)
= 1.27 x 10^9
No. The standard expressions for gravitational PE between objects (as used in arriving at the equation for total energy) have infinity as the PE = 0 reference. Read this: http://hyperphysics.phy-astr.gsu.edu/hbase/mechanics/gravpe.html#c1"
Sure.
ok great, thank u for all ur help
it was really appreciated
1. How is internal energy loss from friction calculated in satellite fall?
The internal energy loss from friction in satellite fall is calculated using the equation E=Fd, where E represents the internal energy loss, F represents the force of friction, and d represents the distance over which the force is applied. This equation takes into account the work done by friction, which results in a decrease in the kinetic energy of the satellite.
2. What factors affect the internal energy loss from friction in satellite fall?
The internal energy loss from friction in satellite fall can be affected by various factors, including the surface material of the satellite, the speed at which it is falling, and the atmospheric conditions. Additionally, the surface area of the satellite and the angle of its trajectory can also impact the amount of internal energy loss.
3. Is the internal energy loss from friction in satellite fall significant?
The amount of internal energy loss from friction in satellite fall can vary depending on the aforementioned factors. In some cases, it may be negligible, while in others it can significantly impact the amount of energy available for the satellite to perform its intended tasks. Therefore, it is important to consider and calculate this energy loss in the design and operation of satellites.
4. Can internal energy loss from friction in satellite fall be reduced?
Yes, internal energy loss from friction in satellite fall can be reduced by using materials with lower coefficients of friction, increasing the surface area of the satellite, and adjusting the angle of its trajectory. Additionally, implementing measures such as lubrication or air resistance can also help minimize internal energy loss.
5. How is the internal energy loss from friction in satellite fall relevant to satellite design and operation?
The internal energy loss from friction in satellite fall is an important factor to consider in satellite design and operation as it can impact the efficiency and performance of the satellite. By accurately calculating and minimizing this energy loss, satellites can be designed and operated in a more effective and sustainable manner.
