Circular to elliptical path
  1. Apr 13, 2013 #1
    A satellite is at an altitude of 3R (R- Radius of the planet) circulating around the planet with a velocity v. In order to make its path elliptical the velocity is changed from v to βv. What should be maximum value of β such that the satellite doesn't collide with the planet?
    2. Relevant equations
    First the expression of V is the orbital velocity and
    Initial energy = final energy.( in terms of Gravitation)
    I cant remember any other equation.
    3. The attempt at a solution
    I tried but i didn't get the right answer.. The answer is sqrt(2/5)..Thanks in advance for help..
  3. Apr 13, 2013 #2
    mfb
    2017 Award
    Staff: Mentor
    I think you are looking for a minimal value.
    Consider the case where the satellite is just "touching" the surface: There are two ways to calculate its velocity, based on two conserved quantities of orbits. They both have to give the same result for a real orbit, this allows to calculate β.
  4. Apr 13, 2013 #3
    Please tell your calculation.. i have also taken the consideration of just touching the surface. .
  5. Apr 13, 2013 #4
    mfb
    2017 Award
    Staff: Mentor
    It is your homework problem, not mine. I know how to do it, I don't have to learn that any more.
  6. Apr 13, 2013 #5
    Is the answer coming?
  7. Apr 13, 2013 #6
    mfb
    2017 Award
    Staff: Mentor
    I helped you to get the answer yourself.
    If you show your work here, I might look for mistakes.
  8. Apr 15, 2013 #7
    I have done the following things:
    0.5mv^2=GMm/4R.
    Then 0.5 Mβ^2V^2-GMm/4R=-GmM/R.
    What's the mistake here?
  9. Apr 15, 2013 #8
    mfb
    2017 Award
    Staff: Mentor
    Where does this come from? It is wrong by a constant factor.
    Why do you have M (instead of m) in the first term? Again, where does the "4" come from? What happened to the velocity at the lowest point of the elliptical orbit?
Have something to add?
Draft saved Draft deleted
Similar Discussions: Circular to elliptical path
Loading...
