Circumscribing an ellipse
  • Thread starter wisredz
Let P(x,a) and Q(-x,a) be two points on the upper half of the ellipse
[tex] \frac{x^2}{100}+\frac{(y-5)^2}{25}=1 [/tex]
centered at (0,5). A triangle RST is formed by using the tangent lines to the ellipse at Q and P.
Show that the area of the triangle is
[tex]A(x)=-f'(x)[x-\frac{f(x)}{f'(x)}]^2 [/tex]
where y=f(x) is the function representing the upper half of the ellipse.
I know f(x) and f'(x). I just cannot get A(x). I'm going mad please help.
Thanks in advance
Answers and Replies
StatusX
2,564
Have you been able to figure out where the third line of the triangle intersects the ellipse?
I never thought of that but that point isn't even related to f(x). But the point is (0,0). I don't understand how to use that point. The triangle's R corner is on the y axis. The other two are on the x axis.
StatusX
2,564
Ok, so just find its base and height. Remember that f'(x) is the slope of the line tangent to the ellipse, so you can use it to find where that line intersects the x and y axes.
Well, it all get's messed up because I do not know what to do when trying to find an equation for one of the edges. That is because I have f'(x) in terms of x and I have the point Q(x,a) and when I try it everyting gets messed up. What should I do now? I had already tried until this point but I always get lost right here...
StatusX
2,564
a=f(x), and point Q is at (x,f(x)). Did you misunderstand this part? Just draw everything. The line passes through Q and has a slope of f'(x). You need the x and y intercepts to get the base and height of the triangle.
The point-slope equation for the tangent passing through the point [itex]Q(x_0,f(x_0))[/itex] would be [itex]y-f(x_0)=f'(x)(x-x_0) [/itex] right? But when I give x the value of 0 I get [itex]x_0[/itex] as the y intersection. Am I doing something wrong here?
StatusX
2,564
The y intercept is the y-value when x=0, so plug in 0 for x and solve for y.
Yeah, I know that. But when I plug in x=0, f'(x)=0. So the right hand side of the point slope equation becomes 0. from here [itex]y=f(x_0)[/itex], which is quite impossible by the figure drawn in the book.
Btw, I'll give f(x) and f'(x) in case that you may spot an error in the calculations.
[tex]f(x)= \frac {(\sqrt(100-x^2)}{2}+5[/tex]
[tex]f'(x)= \frac {-x}{2*\sqrt(100-x^2)} [/tex]
I actually graphed these functions and everything seems to be alright...
StatusX
2,564
that's f'(x0), right?
Thanks a lot, I did it now. My mistake was not using f'(x_0) but instead f'(x). Thanks a lot again...
Related Threads on Circumscribing an ellipse
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
17K
  • Last Post
  • Last Post
  • Last Post
10K
