Clarification about the sign of EMF in batteries and electrochemistry
In summary, electrochemistry defines ##E_{cell}## as the difference between the electrode potentials of the cathode and anode. If the reaction is spontaneous, ##E_{cell}## is positive, but if an external voltage source is needed, ##E_{cell}## is negative. In the physical sense, the EMF from point A to point B is given by ##\varepsilon = -\int_{A}^{B} {\vec{E}} \cdot d\vec{l}##. It is unclear if ##\varepsilon## always equals ##E_{cell}##, but it represents the magnitude of ##E_{cell}##. During discharge, ##V_{cell}## is positive
etotheipi
In electrochemistry, we define ##E_{cell} = E_{cat} - E_{an}##, the difference between the electrode potentials of the cathode and the anode. This has the effect that if the reaction is spontaneous, we obtain a positive ##E_{cell}## and if it is not - i.e. we need an external driving voltage source in order to fix one as the cathode and the other as the anode - ##E_{cell}## comes out as negative. This is fine, since if we are driving a cell "backward" then the half cell at lower potential is in this case fixed as the cathode, and the change in potential going from the anode to the cathode (as is the definition of ##E_{cell}##) is negative.
In a Physical sense, the EMF from point A to point B is given by
$$\varepsilon = -\int_{A}^{B} {\vec{E}} \cdot d\vec{l}$$
With this said, I'm slightly confused as to how ##\varepsilon## relates to ##E_{cell}##. If it is always the case that ##\varepsilon = E_{cell}##, then the implication is that the integral is always from the anode to the cathode (again this would be fine, but I haven't been able to find a reference that says this!).
The problem is that most of the time (in Physics anyway) ##\varepsilon## is given as a positive value even when the cell is being driven backward/charged - which doesn't seem consistent with the electrochemical definition of ##\varepsilon##.
So I was wondering if somebody could clarify whether ##\varepsilon## does indeed always equal ##E_{cell}##, or whether it represents the magnitude of ##E_{cell}##. Thanks!
Chemistry news on Phys.org
During discharge
[tex]V_{cell}=\phi_{cat}-\phi_{an}=\int_a^c \mathbf{E}\cdot\mathbf{dl}>0[/tex]
For circuits of no EM induction
[tex]\oint \mathbf{E}\cdot\mathbf{dl}=0[/tex]
[tex]V_{cell}=\int_a^c \mathbf{E}\cdot\mathbf{dl}=-\int_c^a\mathbf{E}\cdot\mathbf{dl} [/tex]
If you think of more complicated case of EM induction, EMF and battery ##\phi_{cell}## work additionary on the circuit.
mitochan said:
During discharge
Thanks for your reply; though if the cathode is at higher potential during discharge, then shouldn’t the electric field vector point from the cathode to the anode? In which case ##\vec{E}## and ##d\vec{l}## are in opposite directions so their dot product is negative, and we would instead require a negative sign out the front?
Ah, you are right.
[tex]\mathbf{E}=-\nabla \phi[/tex]
minus sign.
Likes etotheipi
1. What is the sign of EMF in batteries?
The sign of EMF (electromotive force) in batteries can be either positive or negative, depending on the direction of the flow of electrons. A positive EMF indicates that the battery is supplying energy to the circuit, while a negative EMF indicates that the battery is receiving energy from the circuit.
2. How does the sign of EMF affect the direction of electron flow?
The sign of EMF determines the direction of electron flow in a circuit. Electrons flow from the negative terminal of the battery (where they are in excess) to the positive terminal (where they are in demand) in a circuit with a positive EMF. In a circuit with a negative EMF, electrons flow from the positive terminal to the negative terminal.
3. What does a positive EMF indicate about the chemical reactions happening in a battery?
A positive EMF indicates that the chemical reactions happening in the battery are spontaneous, meaning they release energy. This energy is then used to power the circuit. In other words, the battery is producing electricity.
4. Can the sign of EMF change in a battery?
Yes, the sign of EMF can change in a battery. This can happen if the conditions of the battery change, such as the temperature or the concentration of reactants. It can also change if the battery is connected to a different circuit with a different resistance.
5. How does the sign of EMF relate to the direction of current flow in a circuit?
The sign of EMF is directly related to the direction of current flow in a circuit. A positive EMF produces a positive current flow, while a negative EMF produces a negative current flow. This is because the direction of current flow is determined by the direction of electron flow, which is in turn determined by the sign of EMF.
  • Chemistry
  • Electrical Engineering
  • Chemistry
  • Electromagnetism
  • Chemistry
