Class conundrum
  • Thread starter lewis198
Main Question or Discussion Point
Hi guys, I was wondering if you could help me with the following:
1.I declare a class, then put public members into it.
2.Then I make member functions that return values that are computed from the values of other members. These functions would have no input, I guess, so I gave them none. I can actually compile up to this point.
3.Then I went onto the main part of the program, int main, and defined a class, and gave the members that are part of the other member functions values. I thought this would then give me a function that I could print values off, but when I tried to, the error message was:
'invalid use of member. Did you forget the '&'?'
The file looks like this:
class name
member 1
member 2
member n
member_function()
int main()
class name x;
member1=value;
member2=value;
member3=value;
printf("%d",x.member_function);
Thanks for your time.
Answers and Replies
#3 should read:
3.Then I went to the main part of the program, int main(), instantiated a class, and gave the properties of that class, their proper values.
Eus
94
Hi Ho!
Code:
member1=value;
member2=value;
member3=value;
It should be:
Code:
x.member1=value;
x.member2=value;
x.member3=value;
because they belong to the object, not to the class.
Also,
Code:
should be
Code:
printf("%d",x.member_function());
because you invoke a method.
Best regards,
Eus
KTC
90
Assuming this is C++, there's a ';" after the closing brace of the class declaration, and you need to declare the various members to be public as otherwise they are private by default.
thanks guys, appreciate it
Related Threads on Class conundrum
  • Last Post
  • Last Post
  • Last Post
