Classical Light Theory: E = kA²f?
In summary, according to classical light theory, the energy in an electromagnetic wave is proportional to the amplitude of the wave squared (A²). However, the doppler effect disproves this idea, as the energy in the shorter wavelength wave is now distributed in less space, which gives a higher amount of energy per unit "volume space", which I believe is the property actually measured. Two observers comparing measurements of the two waves would argue that the energy is proportional to the frequency, since the energies and frequencies mismatch equally much, and the amplitudes are the same.
Hydr0matic
197
According to classical light theory the energy in an electromagnetic wave is proportional to the amplitude of the wave squared (A²). Doesn't doppler effect disprove this idea ?
Picture an oscillating charge going up and down, emitting two waves in opposite directions perpendicular to the oscillation. The two waves will have the same energy, equal in amplitude and wavelength.
Now, if we were to apply a doppler effect to this oscillation, what would happen ? The emitted energy on each side would stay the same, as would the amplitude. The wavelength on the other hand, would increase in one direction and decrease in the other.
Well, all is fine then - The energy is proportional to the amplitude since it does not change and the wavelength does... ... right ?
.. Wrong. Spatial distribution is not accounted for in this conclusion. As a result of the doppler effect, the energy in the shorter wavelength wave is now distributed in less space, which gives a higher amount of energy per unit "volume space", which I believe is the property actually measured. Two observers comparing measurements of the two waves would argue that the energy is proportional to the frequency, since the energies and frequencies mismatch equally much, and the amplitudes are the same.
My conclusion is that, in classical light theory, the energy in an electromagnetic wave should be proportional to the amplitude squared and the frequency.
E = kA²f ? :smile:
Science news on Phys.org
I presume you would accomplish this by changing frames of reference (either yours or its) so that you perceive the oscillator as moving as well as oscillating along one dimension?
Don't forget that the magnitudes of the EM field (i.e. the amplitude of the wave) is affected by changing reference frames, and that conservation of energy does not apply between reference frames.
I haven't done the calculations on what I think would actually happen, but these are effects you need to consider in your argument.
Hurkyl
Yes, of course.
How is the amplitude affected, specifically ? About the energy, I'm not talking about the difference between reference frames, but the difference between the emitted waves. The total energy emitted forwards should equal the total energy emitted backwards in any referenceframe, correct ? [?] (not sure)
I am not to sure how you envisage the event you describe. It was once pointed out to me that it is the distance along the curve of the wave thar remains constant therefore the doppler shift between two waves, should increase one amplitude and decrease the other, keeping the distance along the curve the same in both waves.
However I should point out that I have no formal training in physics so you would need to check this mathematically.
But it does seem logical that if the energy of the wave is unchanged then the amplitude must increase if the wave-length is shortened and vice-versa. If the energy of the wave is altered the situation is different but then of course, you have done something more than a doppler shift.
Ok I know the trick. It's a pitfall of relativity of simultaneity!
In the (average) reference frame of the oscillator, we measure the "front" and "back" waves simultaneously to see that they're equal.
When we switch frames, the two events that were simultaneous in the oscillator's frame are no longer simultaneous, so we should not expect that measuring the total energy of the front and back waves yield equal results.
As for the change in amplitude, I don't have my link to the translation of Einstein's paper, so I don't have a reference as to how EM fields transform when you apply a Lorentz transformation.
The reason the energy density of an EM wave is proportional only to the amplitude squared is because electromagnetic energy density U is:
U = (E2 + B2)/2
in units where c = &mu0 = &epsilon0 = 1
The average value of E2 is proportional to Emax2, it doesn't matter how fast E is varying, so the average energy density doesn't depend on &omega.
Hurkyl
1. What is Classical Light Theory?
Classical Light Theory, also known as Classical Electrodynamics, is a branch of physics that describes the behavior of light as an electromagnetic wave. It was developed by James Clerk Maxwell in the 19th century and is based on the principle that light is made up of electric and magnetic fields.
2. What does the equation E = kA²f mean in Classical Light Theory?
In Classical Light Theory, the equation E = kA²f is known as the electromagnetic wave equation. It describes the relationship between the electric field (E), the area through which the light is passing (A), and the frequency of the light (f). The constant k is known as the wave number and is dependent on the medium through which the light is traveling.
3. How is Classical Light Theory different from Quantum Mechanics?
Classical Light Theory and Quantum Mechanics are two different theories that describe the behavior of light. Classical Light Theory is based on the idea that light is a continuous electromagnetic wave, while Quantum Mechanics describes light as discrete particles known as photons.
4. What are some applications of Classical Light Theory?
Classical Light Theory has many practical applications, including in the development of telecommunications technology, lasers, and fiber optics. It also helps in understanding the behavior of light in various materials and environments, such as in lenses and mirrors.
5. Is Classical Light Theory still relevant in modern physics?
Yes, Classical Light Theory is still relevant in modern physics. While it has been replaced by Quantum Mechanics as the primary theory for understanding light, it is still used in many practical applications and provides a foundation for understanding more complex theories of light and electromagnetism.
  • High Energy, Nuclear, Particle Physics
