Maximizing Rotation: Solving the Clay & Pivoting Rod Problem
  • Thread starter bcjochim07
  • Tags
    Clay Rod
In summary, the ball of clay rotates at an angle of 11.62 degrees when it hits and sticks to the rod.
bcjochim07
374
A 75 g 30 cm long rod hangs vertically on a frictionless, horizontal axle passing through its center. A 10g ball of clay traveling horizontally at 2.5 m/s hits and stick to the very bottom tip of the rod. To what maximum angle measured from the vertical, does the rod with attached ball of clay rotate?
I have a few questions as I am writing down things to start this:
Can I calculate the moment of inertia for the rod and the moment of inertia for the ball around the pivot point and add those together?
Then I think I'll use conservation of energy where K of the ball initial = the rotational kinetic energy of the clay and rod. Then somehow I have to equate that to potential energy. The trouble I'm having is can I just use mgh with the total mass of the ball of clay and the rod as m, or does the fact that this is an extended object make a difference?
bcjochim07,
Yes, the moment of inertia of the two objects about the pivot point is the sum of their separate moments of inertia about the pivot point.
There is a problem with using that the initial kinetic energy of the ball equals the rotational kinetic energy of the ball+clay. Energy is not conserved in the collision. But what is conserved?
The gravitational potential energy of an object depends on the height of the center of mass of that object (for these objects near the Earth's surface). You can either treat these as two objects and find two potential energies, or find their common center of mass and treat them as a single object.
Momentum is conserved in the collision. But why isn't energy conserved?
Energy is not conserved because the ball sticks to the rod. (Also, in collisions of everyday objects you can't assume energy is conserved. Unless somehow they let you know that the collision is elastic, you usually have to assume that energy is lost.)
Linear momentum conservation is not as useful as angular momentum in this case--the rod is rotating and so the entire rod has a common angular speed; different parts of the rod have different linear speeds.
Specifically about the non-conservation of energy for this problem, work is done in deforming the clay during the collision, heat is formed during the collision, etc. This work is not transformed back into kinetic energy at the end of the colliison.
Ok, so would for angular momentum, would this work
(.01kg)(.15m)(2.5m/s)= I* omega
where I is the moment of inertia of the rod with clay stuck to it
then I could use Krot= .5I*omega^2 and then equate that to a potential energy at the max height. For the potential energy, would I use the height of the center of mass?
That's right; the h in the potential energy term is based on the center of mass height.
so for the moment of inertia:
For the rod:
(1/3)(.075kg)(.30m)^2
=.00225 kgm^2
For the clay
(.01kg)(.15m)^2
=2.25E-4
add them: .002475 kgm^2
center of mass: [(.075kg)(.15m) + (.01kg)(.30m)]/.085kg = .1676 m from the pivot
solve for omega w/ angular momentum :
(.01kg)(.15m)(2.5m/s)= (.002475)*omega
omega=1.52 rad/s
Krot= potential energy at the max angle
.5*(.002475)(1.52 rad/s)^2=(.085kg)*g(.1676m-.1676costheta) theta= 11.62 degrees
For the rod:
=.00225 kgm^2
bcjochim07,
The pivot is at the center of the rod. This formula is for a rod pivoted at one end.
Also I think the same problem arises when you calculated the center of mass.
oh yep, I used the wrong pivot poi t
1. What is the "Clay & Pivoting Rod Problem"?
The "Clay & Pivoting Rod Problem" is a classic physics problem that involves a pivoting rod with a massless and frictionless hinge, and a piece of clay attached to one end. The clay is initially at rest and then dropped onto the rod, causing the rod to pivot. The goal is to determine the final position of the clay and the angle of the rod.
2. What are the key concepts involved in solving the "Clay & Pivoting Rod Problem"?
The key concepts involved in solving the "Clay & Pivoting Rod Problem" include conservation of angular momentum, conservation of energy, and the principles of torque and rotational dynamics. It also requires understanding the properties of a simple pendulum.
3. How do you approach solving the "Clay & Pivoting Rod Problem"?
To solve the "Clay & Pivoting Rod Problem", you must first draw a free-body diagram and identify all the forces acting on the system. Then, you can use the principles of torque and rotational dynamics to write equations and solve for the final position and angle. Finally, you can use conservation of energy and angular momentum to check your results and ensure they are correct.
4. What is the significance of the "Clay & Pivoting Rod Problem" in physics?
The "Clay & Pivoting Rod Problem" is a classic example that demonstrates the principles of rotational dynamics and conservation laws in action. It also has real-world applications, such as in designing pendulum clocks and other mechanical systems.
5. Are there any variations of the "Clay & Pivoting Rod Problem"?
Yes, there are variations of the "Clay & Pivoting Rod Problem" that involve different initial conditions, such as the clay being thrown at an angle or the rod being attached to a moving object. These variations can introduce additional complexities but still require the same fundamental principles to solve.
10K
9K
