Clippers in Diodes: Current Flow Explained
  • Thread starter M. next
  • Tags
    Diodes
In summary, the conversation discusses the function of a clipper in a circuit. The clipper removes positive pulses from the output voltage, which is represented on the right side of the figure. The diode conducts on positive peaks, limiting their swing at 0.6v. The reason for removing positive pulses is because the diode does not conduct when it is reverse biased, meaning it is not present for negative excursions of the output voltage. The input voltage, Vi, should be forward biased for positive input voltage in order to remove negative pulses. The diode conducts on positive peaks in order to prevent them from reaching the output. The conversation also mentions the importance of labeling the ground on the figure and clarifies that the diode
M. next
382
Observe the attached figure, and the associated graph, shouldn't be like the opposite of this graph?
If it is positive the first half the current should pass the diode and it is on, no?
The output of the clipper is vo. The clipper removes the positive pulses from vo. The diode conducts on the positive peaks, limiting their swing at 0.6v
Why does it remove the positive pulses?
Why not the negative one?
The diode doesn't conduct when it is reverse biased, so it is effectively not present for negative excursions of vo thus negative pulses are not clipped and they remain unaffected.
The input is on the left, the output is the voltage on the right. Maybe it would be clearer if the line marked "—" were to be labelled "ground". https://www.physicsforums.com/images/icons/icon6.gif
Please elaborate more, I know that the diode doesn't conduct when it is reverse biased.
Here we have Vi as input voltage, and as you can see in the figure it should be forward biased for positive input voltage, and thus we should remove the negative pulse - not the opposite.
The diode conducts on the positive peaks so they don't make it to the output.
Hmm, probably my question is not very clear, right?
The diode allows the passage of voltage if it is in a way that goes along with the pointer head "arrow like" and this " | " or in other words if "Vp-Vn>0".
Let me post my question in a different way: here if voltage from input passes through the diode when it gives a positive pulse, will it be forward biased or not? And why? With details please.
And thanks for your time in advance
1. What is a diode?
A diode is a two-terminal electronic component that allows current to flow in only one direction. It is typically made of semiconductor materials, such as silicon or germanium, and is commonly used in electronic circuits to convert AC power to DC power.
2. How do clippers work in diodes?
Clippers in diodes are used to limit the maximum and minimum voltage levels of an electrical signal. They work by selectively conducting current in one direction and blocking it in the other direction, effectively "clipping" off the peaks of the signal above a certain threshold.
3. What is the difference between a series clipper and a shunt clipper?
In a series clipper, the diode is connected in series with the signal source and the load, while in a shunt clipper, the diode is connected in parallel with the load. This difference in configuration affects the way the diode limits the voltage levels of the signal.
4. How does the current flow in a diode?
The current in a diode flows from the anode (positive terminal) to the cathode (negative terminal) when the diode is forward biased, meaning the anode is at a higher potential than the cathode. When the diode is reverse biased, current flow is minimal as the diode acts as an insulator.
5. What are some applications of clippers in diodes?
Clippers in diodes are commonly used in electronic circuits to protect sensitive components from high voltage levels, to shape the waveform of signals, and to rectify AC power to DC power. They can also be used in audio and video processing to remove unwanted noise or distortion from signals.
  • Electrical Engineering
