ador250
- 2
a clock was set 10 am 20 minutes 30 second ? what will be the angle between hour & second hand ??
ans : 130.25° or 133° which one is correct? I'm confused
jbriggs444 said:The more interesting question is how the other answer was obtained.
Offhand, it looks like a factor of 12 got erroneously applied to the seconds correction.
Ryuzaki said:... Then, for the remaining 30 seconds, he mistakenly calculated the angular distance traversed by the minute hand, which turns out to be 3°...
The formula for calculating the angle between the hour and second hand is:
Angle = |(30 * H) - (5.5 * M)|
Where H is the current hour and M is the current minute. The absolute value is used to account for the possibility of the angle being greater than 180 degrees.
To convert the angle between the hour and second hand from degrees to minutes, you can use the formula:
Minutes = (Angle * 2) / 3
This will give you the number of minutes that have passed since the hour hand and second hand were aligned.
The angle between the hour and second hand can be greater than 180 degrees when the hour hand is moving past the next hour mark and the second hand is close to the preceding minute mark. This happens because the hour hand moves slower than the second hand, causing the angle between them to increase.
The angle between the hour and second hand changes throughout the day as the hour hand and second hand move continuously. The angle is constantly changing and can range from 0 degrees (when the hands are aligned) to 180 degrees (when the hands are directly opposite each other).
The angle between the hour and second hand can be used to tell time by determining the number of minutes that have passed since the hour hand and second hand were aligned. This can be done by using the conversion formula mentioned in question 2. The result can then be added to the current hour to get the time in minutes. For example, if the angle is 130.25 degrees, then the time would be 2:10 minutes past the current hour.
