How can I clone a USB drive to a VFD file for use in Windows?
In summary, the individual is looking for a way to clone a USB drive to a disk file that can be mounted under Windows, in order to send the file to others instead of the physical USB drive. The person has tried using dd/mount under Linux, but cannot find a way to do the same under Windows. They have looked into using VFD or ISO files, but have not been successful. They have also tried using xcopy, but it does not copy the entire disk, only the logical structure. The person is now seeking advice and ideas on how to achieve their goal, but has encountered some unexpected problems with virtual disks and dynamic expanding options. They are hoping for a simple and effective solution similar to what is possible under Linux.
Borek
Mentor
28,947
4,239
TL;DR Summary
looking for a free software tool to clone pendrive to VFD
I have a USB drive that I want to clone to a disk file to be mounted under Windows (so that I can send the file to people instead of sending them the pendrive itself).
Doing so under linux is trivial with dd/mount, technically I see no reason why it couldn't be done under Windows as well, but I can't find a way. VFD sounds like a solution, but I can't find a way to copy the pendrive content to the VFD file. Note: it is not just about copying the visible files, that would be trivial. I need to copy everything, including deleted files info in directory sectors and areas that are technically free, but contain data from deleted files. dd/mount does that treating the pendrive as a block device and just copying the content without looking at the logical structure of the data. VFD format specification that I found in Microsoft pages suggests that it should be doable under Windows as well.
There are some 3rd party backup programs that should work, but I wonder if there are no free tools. I found one (sigh, can't remember name right now) in the past but it was not working (or rather: it produced some file that Windows refused to recognize).
Somehow I find it hard to believe such tools don't exist, so I wonder if I am missing something, or use wrong words in my searches.
Any ideas?
Computer science news on Phys.org
Look up "disk management" in Windows. There you have the choice of assigning a drive letter to a disk of assigning it to an empty folder on another drive - which is the same thing as "mount".
If you want to copy "everything" you can use xcopy with a suitable set of switches - or you can buy a third party tool (I prefer "Opus").
Sorry, but you have missed the point:
That's not copying everything. xcopy copies logical structure (files and directories), not the disk itself, that's not what I am looking for. I want people to be able to mount the disk and then use tools for file recovery to see if there are no deleted files. It works perfectly with a pendrive, but I am looking for a way of doing the same without using a piece of hardware.
mount can do much more that assign path to a folder or net drive. You can copy (using dd) whole disk to a file, then mount this file as if it was a disk. That's type of solution that I am looking for.
Can you use ISO files? Plenty of programs do USB to ISO, and I believe ISO files are mountable as drives.
Likes davenn
I believe I have already checked that before Summer and it didn't work. ISO are not using FAT so no way to have deleted and recoverable files.
Thing is, VFD is Windows a file format designed exactly for what I need, easy to create, move between computers and mount. Once mounted VFD becomes a FAT disk visible to all programs. The only problem is conversion.
A search for "disk.imaging free software" returns lots of hits including "10 best ..." summary articles.
Likes davenn
"Imaging" seems to add some new results, thanks for the idea.
Tom.G said:
Create a virtual disk.
Yes, that's more or less the same thing I was talking about, VFD and VHD are very similar (virtual floppy/hard disk). I want to produce this type of file.
There is an unexpected problem with this approach. I bought several series of pendrives (several hundreds of them in total) that were called '8GB'. Unfortunately, each batch a bit different capacity - differences were not large, measured in hundreds of kB. I was told by the seller that's normal and they can't guarantee identical size. Still, that means if I enter the size of VHD during creation in MB, I can't be sure the virtual disk will have the exact required size, so even the sector by sector cloning doesn't have to work. Actually that was why at least one of the programs I tested failed and why I look for a one step solution (program that reads the exact size from the pendrive before creating the image).
OK, perhaps I misunderstood the specific problem. On the surface, it would seem you could specify an over-sized VHD and then clone your contents to it, leaving the 'extra' space as 'unallocated'.
There is also the Dynamic Expanding option as shown in:
https://www.windowscentral.com/how-create-and-set-vhdx-or-vhd-windows-1011. Under "Virtual hard disk type," select the Dynamic expanding option.
Yes, leaving the extra space can be an option. Actually that's what I did on one of the batches of pendrives that were slightly larger, so I know it works at least for hardware devices cloned with dd under Linux. Question is, will Windows allow non matching sizes, they tend to pretend they are wiser than the user. One of things to research and test.
I know about the dynamic expanding. I am a bit reluctant to trust it, as it means there is no simple dependency between the physical and logical sector address. That in turn probably means it can't guarantee correct working of the file recovery software.
Sorry if I sound like rejecting most of the advice, I already tried/found/thought about many of these solutions and they didn't look promising, as the problem is rather specific. What is most irritating is that it has a simple and effective solution under Linux, so I hoped for an equivalent approach under Windows. I am not aware of any technical reason to why not, yet I can't find anything.
sysprog said:
OSFClone and OSFMount are available free from PassMark: https://www.passmark.com/products/index.php#2
But they don't create VFD nor VHD format which can be mounted in Windows without installing third party software, which I want to avoid (ie. don't force users to install anything, idea is to create something that is supported by plain vanilla Windows).
Just in case someone gets here in the future: someone at SuperUser suggested a tool that does exactly what I wanted: VirtualBox has a command line tool VboxManage, one of the commands it executes is convertfromraw (born conwertdd - so it was initially designed exactly around the approach I needed). Worked perfectly and did exactly what I needed.
Likes sysprog and Tom.G
1. How do I clone a USB drive to a VFD file?
To clone a USB drive to a VFD file, you will need to use a disk cloning software. There are many options available, such as Clonezilla, EaseUS Todo Backup, and Macrium Reflect. These programs will allow you to create an exact copy of your USB drive onto a VFD file.
2. Can I use a VFD file on Windows?
Yes, you can use a VFD file on Windows. VFD stands for "Virtual Floppy Disk," and it is a type of virtual disk that emulates a floppy disk drive. You can mount the VFD file on your Windows computer and access the files inside, just like a regular USB drive.
3. What is the benefit of cloning a USB drive to a VFD file?
The main benefit of cloning a USB drive to a VFD file is that it allows you to create a virtual copy of the USB drive. This means that you can access the files on the USB drive without physically plugging it in, which can be useful if you need to access the files on multiple computers or if the USB drive is damaged or lost.
4. Can I clone a USB drive to a VFD file without using additional software?
No, you will need to use disk cloning software to clone a USB drive to a VFD file. This is because the cloning process involves creating an exact copy of the drive, including all the files and file system. This cannot be done manually without specialized software.
5. Are there any risks involved in cloning a USB drive to a VFD file?
There are minimal risks involved in cloning a USB drive to a VFD file. However, it is always recommended to back up your files before proceeding with any disk cloning process. It is also essential to make sure that the cloning software you are using is reputable and reliable to avoid any potential data loss.
  • Computing and Technology
