Close Packing of Spheres in Regular Tetrahedral vs. Square Pyramidal C
In summary, the post discusses the comparison of packing density of equal-sized congruent spheres in a regular tetrahedral container and a square pyramidal container. The results show that the packing efficiency of spheres in a regular tetrahedral container is higher than in a square pyramidal container. This could have practical applications in packing spherical objects such as oranges, tennis balls, and cannonballs. However, the packing of hard-sphere fluids is a well-studied problem and has shown that the FCC and HCP arrangements have higher packing densities compared to random close-packed spheres.
fizixfan
105
33
The full title of this post is "Close Packing of Spheres in Regular Tetrahedral vs. Square Pyramidal Container"
I'm not sure where this post belongs, but Greg Bernhardt suggested I just post it where I thought best, and he would find a place for it. So here goes:
In 1611, Johannes Kepler proposed that face-centered cubic packing achieves the greatest density. In 1998, Thomas Hales proved he was right.
I took a different approach on this and compared the packing density of equal-sized congruent spheres within a regular tetrahedral container (four similar equilateral triangular faces) vs. a square pyramidal container (four similar equilateral triangular faces with a square base), as shown below:
(Figure 1)
(Figure 2)
I found that, with a very large number of spheres (>100,000), the "packing efficiency" of spheres (volume of spheres/volume of container) within a regular tetrahedral container approached ≈74.048% ("Hales' density" or ∏/√18 ), whereas the packing efficiency of spheres within a square pyramidal container approached only ≈60.460%.
Oddly enough, the space-efficiency of a tetrahedral ball stack decreases in proportion to the number of balls it contains, whereas the space-efficiency of a pyramidal ball stack increases with the number of balls, as shown below:
(Figure 3)
(Figure 4)
Here are the formulas I used in my calculations (note that I let the radius of each sphere equal 1).
For a regular tetrahedral container:
Volume of each sphere = 4/3∏r³ (r = 1) = 4.1888
Number of spheres in a regular tetrahedron Tt = n(n+1)(n+2)/6 where n = number of spheres along base (n=5 in Figure 1), so the number of spheres in a tetrahedron with 5 spheres along the base would equal 35.
Volume of spheres in a regular tetrahedron = Vst = n(n+1)(n+2)/6*4/3*∏r^3 ≈ 146.608 (for n=5)
Length of side of regular tetrahedral container = b = ((2n)-2)+2*3^0.5 = 11.464 (for n=5)
Volume of regular tetrahedral container = Vt = b^3/6*2^0.5 = (((2n)-2)+2*√3)^3/(6*(2^0.5)) = 177.564 (for n=5)
"Packing efficiency" = Vst/Vt ≈ 82.566% (for n=5)
The packing efficiency of a regular tetrahedral container decreases with the number of spheres until it reaches a limit of ≈74.048% (Figure 3). Note that the packing efficiency actually increases between 1 sphere to 4 spheres. This is unexpected, and could be an error in my calculations, or it could be accurate. I've checked it numerous times. Feel free to check it for yourself.
For a square pyramidal container:
Volume of each sphere = 4/3∏r³ (r = 1) ≈ 4.189
Number of spheres in a square pyramid = Tp = n(n+1)(2n+1)/6 where n = number of spheres along base (n=4 in Figure 2), so the number of spheres in a square pyramid with 4 spheres along the base would equal 30. With 5 spheres along the base, the total number of spheres would equal 55. (I couldn't find an illustration that showed 5 spheres along the base, so I had to use the one with 4 spheres along the base).
Volume of spheres in a square pyramid = Vsp = n(n+1)(2n+1)/6*4/3*∏r^3 ≈ 230.383 (for n=5)
Length of side of square pyramidal container = b = ((2n)-2)+2*3^0.5 ≈ 11.464 (for n=5)
Height of square pyramidal container = h = (((n*2-2)+(2*(3^0.5)))*3^0.5/2) ≈ 9.928 (for n=5)
Volume of square pyramidal container = Vp = b^2*h/3 = ((((2*n)-2)+2*3^0.5)^2*(2n)-2) + 2*(3^0.5)*2/3^0.5)/3 ≈ 434.94 (for n=5)
"Packing efficiency" = Vsp/Vp ≈ 52.969% (for n=5)
The packing efficiency of a square pyramidal container increases with the number of spheres until it reaches a limit of ≈60.460% (Figure 4).
There may be practical applications for this (if my calculations are right) for the packing of spherical objects (oranges, tennis balls, baseballs, cannonballs, etc.). If so, it would mean that the more space efficient container for packing equal-sized spheres would be a regular tetradhedral container rather than a square pyramidal container.
Your comments are welcome!
Fizixfan.
Clearly, if the number of balls doesn't exactly fill a level, it will be less efficient to package.
It depends on what you mean by "exactly." All the balls in both stacks are touching all the adjacent balls. It's the size of the interstitial spaces that makes the difference.
<snip>
I'm not exactly sure what your question is, but the packing of hard-sphere fluids is a long-studied problem. From experiments and simulations, we know:
1) the density (volume fraction) of random close-packed spheres in three dimensions is 0.638, compared with 0.7405 for FCC (face-centered cubic) or HCP (hexagonal close packed) arrangements.
2) a hard-sphere phase diagram is athermal, since the sphere-sphere interaction is either zero or infinite.
3) there is a solid-liquid phase transition as a function of volume fraction. On the phase boundary, a liquid phase with packing fraction 0.495 is at equilibrium with a FCC solid with a volume fraction of 0.545.
Further, by examining the lattice structures of close-packed arrangements, we find the primitive unit cell of FCC is not a cube but a (IIRC) cuboctohedron.
If we denote the possible 2-D triangular close-packed lattices A, B, and C (based on where the coordinate origin is), FCC is obtained by stacking ABCABCABC... while HCP is ABABABABAB..
I was trying to eliminate the square pyramidal arrangement as an efficient way of packing spheres. In one of the other forums, someone had said it was the same as a regular tetrahedral arrangement. I had to demonstrate, to myself at least, that it was not.
You can see that interstitial spaces in the "plan" of the square pyramid base (1st figure) are larger than those in the tetrahedron base (2nd figure). I also stacked some golf balls to hopefully give a real-world of demonstration of what I'm trying to do here (3rd and 4th figures). When a very large number of balls is used, the density of the pyramidal arrangement is ~0.6046, whereas the density of the tetrahedral arrangement is ~0.7048. I've shown this in the calculations listed in my initial post.
Perhaps Thomas Hales used the square pyramidal arrangement in his proof of the Kepler Conjecture (i.e., that this was NOT the most efficient, or densest, way of stacking equal-sized congruent spheres).
It may not be rocket science, but if you can't have fun solving geometric puzzles, what's the point?
fizixfan said:
...whereas the density of the tetrahedral arrangement is ~0.7048. I've shown this in the calculations listed in my initial post.
~0.7048 is incorrect. I meant ~0.74048.
These are indeed the same structures, just oriented (and therefore terminated) differently.
Try to remove the 5 balls along the edge of the tetrahedral pyramid. You will see squares of 4 ball touching each other in a square arrangement, just as in the base of your square base pyramid.
The stacking is known as face-centered cubic (FCC) and occurs in many common metals such as copper.
I tried removing the 5 balls along the edge of the tetrahedral pyramid, but I still did not see 4 balls touching each other in a square arrangement.
In the illustration above, the balls in the square arrangement are show in the first figure. Notice that the ball in the center is touching eight other balls. In the second figure, the base layer of the tetrahedral arrangement, the center ball is touching only six other balls, making it denser. Not to complicate things too much, but the second figure is also a cross-sectional view (looking horizontally at the stack) of both the square pyramid and the tetrahedron. But it's the way the balls are arranged in each horizontal layer of the stack that makes the difference in the density.
I found this at: http://www.had2know.com/academics/pyramid-of-balls-height-calculator.html
"There are two ways to stack spheres into a pyramid. One is to start with a square base, adding layers of smaller squares on top until you reach the apex. Another is to start with a triangular base and build up the layers with successively smaller triangles.
"Mathematically, both of these arrangements are the most efficient way to pack spheres in three dimensional space; each arrangement has a packing density of π/√18 = 0.74048. This means in either pyramidal formation the spheres occupy 74.048% of the available space."
I found this to be true, but only with very large numbers of spheres (>10,000). The density of the tetrahedral arrangement decreases with each successive layer of spheres, while the pyramidal arrangement increases as more layers of spheres are added, until they approach convergence at ~20,000 spheres.. Here are two graphs illustrating this:
1. What is the difference between close packing of spheres in regular tetrahedral and square pyramidal?
The main difference between close packing of spheres in regular tetrahedral and square pyramidal is the arrangement of the spheres. In regular tetrahedral packing, the spheres are arranged in a way that each sphere is surrounded by four other spheres, forming a tetrahedron. In square pyramidal packing, the spheres are arranged in a way that each sphere is surrounded by five other spheres, forming a square pyramid. This difference in arrangement results in different packing efficiencies and stability.
2. Which type of close packing is more efficient?
In terms of packing efficiency, regular tetrahedral packing is more efficient than square pyramidal packing. This is because in regular tetrahedral packing, each sphere is in contact with four other spheres, while in square pyramidal packing, each sphere is in contact with only five other spheres. This leads to a higher percentage of space being occupied by the spheres in regular tetrahedral packing.
3. What is the coordination number for both types of close packing?
The coordination number is the number of nearest neighboring spheres that each sphere is in contact with. In regular tetrahedral packing, the coordination number is 4, as each sphere is in contact with four other spheres. In square pyramidal packing, the coordination number is 5, as each sphere is in contact with five other spheres.
4. How does the packing efficiency vary with the size of the spheres?
The packing efficiency of both types of close packing decreases as the size of the spheres increases. This is because larger spheres require more space between them to avoid overlapping, resulting in a lower packing efficiency. However, regular tetrahedral packing has a higher packing efficiency than square pyramidal packing for all sizes of spheres.
5. What are the real-life applications of close packing of spheres?
Close packing of spheres is a fundamental concept in materials science and has many real-life applications. Some examples include the arrangement of atoms in crystals, the structure of biological molecules, and the packing of particles in emulsions and foams. Understanding and controlling close packing of spheres is crucial in various industries, such as pharmaceuticals, cosmetics, and construction. It also has applications in fields such as nanotechnology and nanomedicine.
  • Other Physics Topics
  • Precalculus Mathematics Homework Help
  • Science Fiction and Fantasy Media
