Closed form for integral
stevendaryl
Staff Emeritus
Insights Author
8,401
2,578
Main Question or Discussion Point
Does anyone know whether the following integral has a closed-form solution? If not, is anything known about the asymptotic behavior?
[itex]f(x) = \int_{-\infty}^{+\infty} \frac{e^{iux}}{\sqrt{u^2 + 1}} du[/itex]
Answers and Replies
Paul Colby
230
Does it help that ##f''(x)-f(x)=\delta(x)##?
Oops missed the square root
Charles Link
Insights Author
1,934
I don't know the complex variable residue theory as well as I should, but for x>0, I think the contour closes in the upper half plane and has a single pole at z=+i inside the contour so that ## f(x)=2 \pi i exp(-x) ##. For x<0, the contour would close in the lower half plane with a pole at z=-i and the counterclockwise path would give a minus sign, so that ## f(x)=-2 \pi i exp(+x) ##. I'm not sure about this function with the sqrt. in the denominator is considered to have simple poles. Perhaps @micromass can answer that. editing... and I missed the term of sqrt (2i) in the denominator for the part without the pole. Will need to research this further...editing ... multiplying numerator and denominator by sqrt (u^2+1) gives the function simple poles, but I'm still at the drawing board=perhaps there is a simple solution... editing... thought I had a possible answer, but still at the drawing board...
61
It is modified Bessel functions of the second kind ##K_0(x)## (I assume ##z=x## in your integral), see, for example, here, equation (6). You should find a lot of information about Bessel functions (as well as about all other special functions) in Abramowitz and Stegun.
Likes Paul Colby and Charles Link
stevendaryl
Staff Emeritus
Insights Author
8,401
2,578
Thanks. I should have noticed that the imaginary part of my integral vanishes by symmetry.
Related Threads on Closed form for integral
  • Last Post
  • Last Post
  • Last Post
