Cluster Speed Advice
  1. Jul 18, 2006 #1
    Fastest Computer
    Where would I find information on the fastest computers in the world?
  3. Jul 18, 2006 #2
    Here is a http://www.top500.org/lists/2006/06" [Broken]
  4. Jul 18, 2006 #3
    can u convert 280.6 TFlop/s to a more managable unit?
    also, how fast is one megaflop
  5. Jul 18, 2006 #4
  6. Jul 18, 2006 #5
    Well I do not understand your question.
    A flop is one floating point operation (an operation on a non-integer).
  7. Jul 18, 2006 #6
    How fast is a Teraflop?
    Can someone convert 280.6 TFlop/s to more managable units?
    also, how fast is a megaflop?
  8. Jul 18, 2006 #7
    What exactly is a cluster?
    How fast are the fastest clusters, and does anyone know how fast the cluster(s) is/are at the University of Richmond?
  9. Jul 18, 2006 #8
    My mistake
    how many flops/s can any ordinary pc run? and how would i compare that to the fastest (280.6 TFlop/s)
  10. Jul 18, 2006 #9
    woops. not how fast, but how many flops are in a megaflop, or a teraflop?
  11. Jul 18, 2006 #10
    Mega and tera are both greek words.
    Mega stands for 1 000 000
    Tera stands for 1 000 000 000 000
  12. Jul 18, 2006 #11
    prefix mega means 10^6 over the basic unit.
    prefix giga means 10^9 over the basic unit.
    prefix terra means 10^12 ............
    so there are flops in a terra flop flops in a giga flop and so on....
    These prefixes can be applied to any unit, not just to flops(i.e. MegaByte but here is a kinda different story because the basic units are in bynary not decimal.)
  13. Jul 18, 2006 #12
    Staff: Mentor
    A megaflop is a measure of a computer's speed and can be expressed as:
    A million floating point operations per second
    10 to the 6th power floating-point operations per second
    2 to the 20th power FLOPS
    Also http://en.wikipedia.org/wiki/Petaflops
    megaFLOPS (MFLOPS) is equal to one million floating-point operations per second, and a gigaFLOPS (GFLOPS) is equal to one billion floating-point operations per second. A teraFLOPS (TFLOPS) is equal to one trillion floating-point operations per second.
    You should be able to calculate it with this information.
  14. Jul 18, 2006 #13
    Staff Emeritus
    Well, 'terra' actually means 'ground' or 'land'. :wink:
    It's 'tera' which is 1000 times bigger than 'giga'!
  15. Jul 18, 2006 #14
    Staff: Mentor
    First, you know what the prefixes mean, right?
    Kilo = 1,000
    Mega = 1,000,000
    Giga = 1,000,000,000
    Tera = 1,000,000,000,000
    For the processing power of pc's, hardware review sites have them. Here is a sample: http://www.tomshardware.com/2006/07/14/core2_duo_knocks_out_athlon_64/page16.html
    Newer pc's are on the order of 10-20 gigaflops, so about 10,000 times slower than a supercomputer (which, incidentally, are often just clusters of several thousand desktop processors).
  16. Jul 18, 2006 #15
    Andrew Mason
    It is a term used in astrophysics, physics, chemistry, computer programming, computer disk drives. Maybe they have some really fast computers at the University of Richmond.
    Check out http://en.wikipedia.org/wiki/Cluster_(physics)" [Broken].
  17. Jul 18, 2006 #16
    Serious Help needed
    how do i found out how to run a test on a cluster to find out the speed?
  18. Jul 18, 2006 #17
    Well that depends what you want to measure.
    Is it pure CPU speed, for each CPU separately or on how they work togeter? Or is it disk throughput, like for some database application, network server performance? There are many things you can measure.
    So it would help if you provided some more information.
  19. Jul 18, 2006 #18
    Cluster Speed
    How do i find out the speed of a cluster? I'm supposed to figure how to run a program to determine the speed of our cluster here at UR.
  20. Jul 18, 2006 #19
    Staff Emeritus
    That's a rather vague question, as we don't know anything about UR's cluster. This sounds like some kind of a lab, though, meaning you should probably have some sort of handout that provides help.
    There may a simple benchmarking program provided for you. Or maybe you have to write your own. If you have to write your own, of course, you'd have to use some kind of cluster library (MPI, etc.) to distribute the work across all the nodes in the cluster, which could be difficult.
    If you have some kind of background information, you should provide it as part of your question. Otherwise, there's really nothing we can do to help you.
    - Warren
  21. Jul 18, 2006 #20
    I dont know really. I was told to just figure out how to determine how many megaflop/s its running and compare it to other clusters (specifically the faster ones). Should I have been given more information or what?
Similar Threads - Cluster Speed Advice Date
Net Neutrality, Bandwidth, Speed, Physics, Greed? Aug 29, 2017
Bulding a cluster Feb 9, 2012
Home Made Linux Cluster May 1, 2010
Beowulf cluster Jul 16, 2009
Cluster computing/botnet Jul 26, 2008
