CMB power spectrum
  1. Jul 29, 2010 #1
    Anyone knows if the CMB map of anisotropies from WMAP is used to implement the angular power spectrum plot(acoustic peaks)? I'm not sure, but I tend to think it is not.
  3. Jul 30, 2010 #2
    No. The way it's done is they typically just use an aggressive mask to get rid of the galaxy and point sources, and estimate the power spectrum based upon that. So far as I am aware, foreground removal is not yet part of the power spectrum estimation strategy from WMAP, largely because there is currently no good way of estimating the uncertainties in foreground removal. There's also the point to be made that foreground removal isn't really necessary for WMAP, except in the sense of removing the galaxy and point sources, because WMAP isn't sensitive enough for the foregrounds to become an issue.
    With Planck, however, due to its increased sensitivity, foreground removal will be absolutely necessary for obtaining optimal science data from the results.
  4. Jul 30, 2010 #3
    Hmmm I thought using a mask to get rid of galaxy emisions and point sources , and foreground removal were basically the same thing, is this not so?
    What other foreground is there to be removed?
    Thanks for answering
  5. Jul 30, 2010 #4
    What I was referring to there is more often called component separation, which involves using the multi-frequency data in order to estimate the CMB itself. This map that the WMAP team released, for example, is produced using one particular algorithm for doing this, dubbed Internal Linear Combination (ILC):
    The basic issue here is that there are things other than the CMB no matter where you look in the sky, but those things tend to have different frequency scaling, so you can pick out which part of the signal is CMB, and which part isn't. It's not a trivial process, and there are multiple techniques of doing it, all with their own strengths and weaknesses. The primary difficulty right now is that proper estimation of errors isn't quite there yet.
  6. Jul 30, 2010 #5
    I see, it all looks quite complex, I guess they have to be really careful with this foreground cleaning, I would suppose there has to be a fine line between being too agresive masking what is not CMB, with the risk of leaving just some kind of random noise, and not masking enough leaving fluctuations in the map that are not really CMB.
Similar Threads - power spectrum Date
A Angular power spectrum, bias from N weighted events Mar 18, 2017
I Primordial Power Spectrum Nov 22, 2016
I Primordial power spectrum Oct 1, 2016
I Scale invariance in the power spectrum Sep 19, 2016
A Plotting the CS power spectrum Feb 17, 2016
