Coefficient of Friction of brakes
In summary, the car is driving at a constant speed of 14.0 m/s and comes to a stop in 25.0 m after slamming on the brakes. The coefficient of sliding friction between the tires and the icy roadbed is approximately 0.40.
sweet877
30
You are driving a 2500.0-kg car at a constant speed of 14.0 m/s along an icy, but straight and level road. While approaching a traffic light, it turns red. You slam on the brakes. Your wheels lock, the tires begin skidding, and the car slides to a halt in a distance of 25.0 m. What is the coefficient ([tex]\mu[/tex])of sliding friction between your tires and the icy roadbed?
W=mg=2500.0(9.8) = 24 500 N
Normal force=Fn=W=24 500 N
Exerted force = Fa = ma = 2500.0 (-3.92) = -9800 N
How do I go on from here?
I'm confused by your last line:
I'm not sure what you're doing there.
You can solve this problem using conservation of energy, you know the initial and final energies of the car and any difference between the two must be due to work exerted by the frictional force.
We haven't learned about conservation of energy yet. By the last line, I was trying to calculate what force I am exerting on the car to make it stop.
Oh I see, the "Fa" is "force which causes acceleration" and not "force times acceleration." Sorry :smile:
OK, so you've calculated the acceleration that the car underwent in order to come to a stop and used that to determine the force which must have been applied to the car in order to stop it, now you need to relate that to your frictional force.
So I'll ask you a question: How do you calculate a frictional force, and what do you need to know in order to do so?
Is the frictional force the opposite of the force that was applied to the car in order for it to stop?
The frictional force is the force that stopped the car. Don't worry about the minus sign though, it's just an issue of which way you call positive. Really the equation for the frictional force should be something like:
[tex]|F| = \mu N[/tex]
... but I can't recall ever having seen it written that way.
Frictional Force shldn be the opposite to the direction of the force..
Frictional forces shld occur opposite to the direction of motion. In this case, friction is still acting on the back of the car. Not opposite to the force applied to the car in order for it to stop.
I tot [tex] \mu [/tex] was what the qn was asking?
So, since [tex]F=\mu N, \mu = F/N = 9800 N/24500 N = 0.40[/tex]?
If the qn assumes that the icy road bed is frictionless.. then yes, the ans is 0.4..
Becoz, the only artificial friction left is the braking force.. and that will be your frictional force.
Yup, that's what I got.
Thanks for your help!
My pleasure :smile:
1. What is the coefficient of friction of brakes?
The coefficient of friction of brakes is a measure of the braking performance of a material or surface. It represents the amount of force required to stop a moving object, such as a vehicle, and is typically expressed as a decimal or percentage.
2. How is the coefficient of friction of brakes determined?
The coefficient of friction of brakes is determined through laboratory testing. This involves measuring the force required to stop a rotating test object on a test surface, and then calculating the ratio of the force to the weight of the object.
3. What factors can affect the coefficient of friction of brakes?
The coefficient of friction of brakes can be affected by various factors such as the type of brake material, the condition of the braking surface, the speed and temperature of the braking process, and the presence of any external substances or contaminants.
4. Why is the coefficient of friction of brakes important?
The coefficient of friction of brakes is important because it directly impacts the braking performance and safety of vehicles. A higher coefficient of friction generally results in better braking ability, while a lower coefficient can lead to longer stopping distances and decreased control.
5. How can the coefficient of friction of brakes be improved?
The coefficient of friction of brakes can be improved through various methods, such as using different brake materials, maintaining a clean and smooth braking surface, and optimizing the design and operation of the braking system. Regular maintenance and proper use of the brakes can also help to improve their coefficient of friction.
