Coincindence Count Rates
  • Thread starter india
  • Tags
    Count
In summary, the probability of both particles being detected simultaneously from a single radioactive source emitting alphas and x-ray photons is dependent on the coincidence interval and the production rate of particles. The coincidence rate can be calculated using the formula R*P(1-2), where R is the production rate and P(1-2) is the probability of coincidence. A more quantitative approach can be found in the provided resource.
india
Coincindence Count Rates !
I have two particle detector,
1. one will counts 13 particle/sec
2. second has 0.138 particle/sec (i.e. 1 particle can be detected in 7.2 sec in second det)
what will be the probability of both particle being detected ? and in how much time ?
Your question is not well phrased, but maybe one can answer it with a bit more information.
What do you mean by "both particle being detected"? Are you asking for the simultaneous detection rate - how often both detectors click at the same time? Then we need to know the time resolution of the detectors or the binning time of the coincidence counting, that means the duration of the time window which is considered as simultaneous. Also can one assume the particles at both detectors to be statistically independent?
Or are you aiming at something entirely different?
As Cthugha said, the experimental situation isn't clear from your question.
If the particles are, say, polarization entangled photons filtered by polarizers, then the probability of coincidental detection is roughly .058 (assuming a coincidence interval of roughly .076 seconds). From which it can be deduced that the angular difference between the polarizers is roughly 76 degrees.
But, as far as I know, coincidence intervals in polarization entangled photon experiments are many orders of magnitude less than that.
So, as far as I can tell, it really isn't clear what you're asking about.
Unless you specify the particle type and source preparation, then from what you've said I would just say that you've got two independent sources, with one source emitting roughly 94 particles every 7.2 seconds and another source emitting 1 particle every 7.2 seconds. If that's the case, and if the particles aren't entangled or filtered in any way, then I guess that the probability of a coincidental detection within a 7.2 coincidence interval is 1 in 94 or .01063.
Yes, Let's say, single radioactive source is emitting both alphas and x-ray photons. now rate of alpha particle being detected in detector is 13 alpha/sec, and rate of x-ray being detected in xray detector is 0.138 photon/sec. Both detector are different. And Let's say count rates have already included source effect and efficiency of detector.
Now, I know, coincidence means detection of two or more events in some time interval Δt. This Δt will be resolving time of coincidence counter. But this I don't knw, but I want to assume theoretically the rate of coincidence in this system. what will be probability of coincidence ? or rate of coincidence ? and How one can decide the specific Δt for their system ?
The true coincidence probability is defined as: The probability to have a signal in detector 2 when you already have a signal in detector 1.
If there are no correlations, then this probability is : P(1-2)=P(1)*P(2)
Therefore, for a given production rate of particles R, you have that the coincidence rate is R*P(1-2)
For a more quantitative approach see this: http://www.phys.columbia.edu/~w3081/exp_files/coin.pdf , pg.2
1. What is a coincidence count rate?
A coincidence count rate is the number of times two events occur simultaneously or within a specific time window. In scientific experiments, coincidence count rates are used to measure the probability of two particles interacting or the accuracy of a detection system.
2. How is coincidence count rate calculated?
The coincidence count rate can be calculated by dividing the number of coincidence events by the total number of events in a given time period. This rate is often expressed as a percentage or a rate per unit of time.
3. What factors can affect coincidence count rates?
There are several factors that can affect coincidence count rates, including the size and geometry of the detection system, the energy and type of particles being detected, and the efficiency of the detection system. Environmental factors such as background radiation and electrical noise can also impact coincidence count rates.
4. Why are coincidence count rates important in scientific experiments?
Coincidence count rates are important in scientific experiments because they can provide valuable information about the behavior of particles, the accuracy of detection systems, and the validity of experimental results. They can also help researchers detect and correct for any systematic errors in their data.
5. What are some applications of coincidence count rates?
Coincidence count rates have a wide range of applications in various scientific fields, including nuclear physics, particle physics, and medical imaging. They are also used in security and detection systems, such as radiation detectors and particle accelerators, to ensure accurate and reliable results.
  • Other Physics Topics
  • Quantum Physics
