Colision Investigation Problem
In summary, the conversation discusses the process of determining the velocity of a car involved in an accident based on various factors such as the distance of skid marks, the coefficient of kinetic friction, and the mass of the cars. Through working backwards and using the principles of energy and momentum conservation, the solution is found and confirmed through images.
2015HuntMJ
You are starting a job for Montreal Police Colision Investigators. Your boss tells you to file a report on an accident on Notre-Dame Street. There has been an accident involving 2 cars.
Your findings are as follows:
  • Numerous debris were found at a distance of 12.25 m from the car
  • The two cars stuck together and there are skid marks over 12.25 m
  • There are also skid marks over a distance of 30 m before your debries
  • The posted speed limit is 70 km/h
  • Other data: m1=2,674 kg and m2=1,100kg
  • From a friction block: Fv= 88.2N and Fh = 75.8N
  • The second car was at rest
Write a report for your superior on wether the car at fault should be charged with speeding (over 70 km/h)
μk = Fk/Fn
The coeficent of kinetic friction is 0.86 (μk = Fv/Fh)
We have:
Mass of both cars
initial velocity of second car (0)
final velocity of first car (0)
We need 2 know:
Initial velocity of 1st car.
How can we do this with only mass, distance of skid marks, and coeffiecent of friction?
Hint: Work backwards. Energy = force * distance. You know the friction force and you know the distance so you can calculate the energy the cars had just after impact. You know their mass so you can calculate their velocity just after the impact.
Hmmm I haven't thought about finding energy.
Since Energy = net force * distance I will need to find net force and I already have distance.
And Fnet = Ff + Fa
Ff = (uk)(Fn)
Ff = 75.8 N
But how do I find Fa?
I think you can assume that the only force decelerating the cars after the impact is friction Ff. What else is there?
You're right the only force would be friction force.
So,
Ff = uk * Fn
Ff = .86 * 88.2 N
Ff = 75.9 N
With friction force i can find energy.
E = F * d
E = 75.9 N * 12.25 m
E = 929.8 J
So now that i know the energy my next step is to find velocity.
KE = (1/2)mv^2
KE = E
929.8 J = (.5)(2674+1100)(v^2)
.49 = (v^2)
.7 meters per second = v
But that is the velocity after the colision. What step do i need to take next to get the velocity prior to the first car breaking?
Continue to work backwards step by step.
I haven't checked your working but once you have the correct velocity of both cars after the impact your next step is to work out the velocity of the moving car just before the impact. Hint: Conservation of Momentum.
Likes 1 person
Solved
We finished the problem. Thank you for your help! Working backwards did the trick.
https://www.dropbox.com/s/3a3ivx9mscn3qxj/2014-03-10%2010.57.32.jpg
https://www.dropbox.com/s/905gzbunimv5fdt/2014-03-10%2010.58.33.jpg
2015HuntMJ said:
Solved
Do you have any working links for this solution? Thank you
Welcome to PhysicsForums.
This thread is from 2014, so it's not likely the poster is still active on the forums (their last activity was from near the end of 2014).
If you have a similar schoolwork problem, start a new thread and fill out the Template with as much information as you can. Show as much work as you can, and you will get good help here. :smile:
1. What is collision investigation problem?
Collision investigation problem is the process of examining and analyzing the factors that contributed to a collision, with the goal of determining the cause and preventing future collisions.
2. What are the steps involved in a collision investigation?
The steps of a collision investigation typically include securing the scene, collecting evidence, interviewing witnesses, analyzing data, reconstructing the collision, and determining the cause.
3. How long does a collision investigation usually take?
The length of a collision investigation can vary greatly depending on the complexity of the collision and the amount of evidence involved. It can take anywhere from a few days to several months to complete.
4. What tools and techniques are used in collision investigation?
Collision investigators use a variety of tools and techniques to gather evidence, including measuring devices, photography, computer simulations, and data analysis software.
5. What are the common causes of collisions?
Some of the most common causes of collisions include speeding, distracted driving, impaired driving, and mechanical failures. Other factors such as road conditions and weather can also contribute to collisions.
