Colliding balls
  • Thread starter Physicsy
Two balls are moving through space in the same direction, the balls have differiential masses and velocitys. Ball A is behind Ball B but is also moving faster so will soon collide with it, my question is "How fast will both balls be moving after they have collided?"
Ball A: mass=10 velocity=20
Ball B: mass=30 velocity=5
Answers and Replies
I think I just figured the answer out,
Ball A: 5
Ball B: 10
Could someone please confirm this for me.
It depends on how elastic the collision is. There are many possible solutions to the problem.
The collision is perfectly elastic and all momentum is conversed
If the collision is perfectly elastic, then the relative velocity at which they move towards each other before collision is the same as the relative velocity at which they separate after the collision.
Before they collide they are approaching with a relative velocity of 20-5 = 15m/s
This means that, in addition to the momentum being conserved, you also know that the balls will separate such that relative velocity is still 15m/s
So, for example, if ball B moves with velocity 10 m/s after the collision, then ball A would need to move at -5 m/s after the collision. That is, at 5m/s in the opposite direction to its original direction.
How have you made this calculation?
The answers cannot be correct if the collision is perfectly elastic.
To get the answer i came up with, I first found the relative velocity, 20-5=15, and then i divided the mass of the heavier Ball B by A to find the multiple difference in mass, 30/10=3, i then divided the relative velocity by this difference to get what i believed to be the change in velocity of Ball B, 15/3=5, so I thought the velocity of Ball B must be, 5+5=10.
I then remeabered that the momentum behind both balls together must always be the same. So i found the momentum of both balls, Ball A=200 Ball B=150, then added them together, 200+150=350. I then took away the after collision momentum of Ball B,
10*30=300 350-300=50, and then figured out the after collision velocity of Ball A through this, 50/10=5.
Unless i made some sort of mistake or everything above is pure bull, i thought the answer would have been,
Ball A=5 (I understand that this is really -5 as the ball would reverse in direction)
Ball B=10
Also when i say perfectly elastic i mean that no kinetic energy during the collision is converted into heat between molecules of the balls, so all energy remains in the momentum.
The relative velocity equation comes from conservation of energy.
If you check your values and work out the total kinetic before and after the collision, you will see that it is not conserved for the vlaues you have calculated.
[I worked it out that there is 2375J before the collision, and 1625J after, if your values are used.]
The way to do this is to 1st apply conservation of momentum
MaUa + MbUb = MaVa + MbVb
Ma=10kg, Mb=30kg, Ua=20m/s, Ub=5m/s, Va and Vb are the velocities after the collision.
This gives
20 x 10 + 30 x 5 = MaVa + MbVb
350 = 10Va + 30Vb
Then write down the relative velocity equation
Ua-Ub = -(Va - Vb)
15 = Vb-Va
From this get an expression for either Va or Vb and substitute it into the momentum equation to get one of the velocities.
Then it's easy to find the other velocity.
I think you may use law of conservation of momentum and law of conservation of KE.
Thanks guys, I understand why it can't be right now.
Related Threads on Colliding balls
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
  • Last Post
9K
