subhradeep mahata
- 120
- 13
I am having a little trouble in understanding a few points of colligative properties. Any help will be appreciated.
First, let's consider RLVP. We know that addition of a non-volatile solute decreases the vapor pressure of a pure volatile solvent. However, I am getting confused between the terms "solvent" and "solution". Here, is the vapor pressure of the solvent reduced, or that of the whole solution? As we can see, vapors of solute are not present as it is non-volatile, hence vapor pressure of the whole solution is simultaneously decreased (meaning that it is less than that of pure solvent).
Now, let's consider elevation in BP. As we add a solute to a pure volatile solvent, is the BP of the solvent increased or that of the whole solution? I went through many solved examples, and I am guessing that it is the solution whose BP is increased: BPsolution = BPpure solvent + ΔTb, where ΔTb=kb×m×i
I have a couple of questions for you:
1) In the calculations of CP, is the solute ALWAYS considered to be non-volatile? If not, then please explain how vapor pressure and BP will be affected by a volatile solute (added to a volatile solvent).
2) The solvent/solution dilemma, especially in elevation in BP and depression in FP. Does the BP of the solvent remain unchanged?
Please try to keep your answer as basic as possible, avoid complicated explanations.
