Collision of a charged and an uncharged particle
In summary, a charged and an uncharged particle collide. The average of the total charge is determined.
Robin04
260
A charged and an uncharged particle collide. What will be their charges after the collision? The average of the total charge?
If total charge is conserved, what do you think the answer is?
If the total charge is conserved, that only means that the total charge in the system is the same before and after the collision. But it doesn't say anything about its distribution.
My guess would be that the two particles will have the same charge, therefore the distribution is determined by the arithmetic mean, but that's only a guess for now.
Good. That's true. But when things collide they might share their charge or keep them separate. There is no universal answer to your question. It depends on what the objects are.
I was a bit careless. The objects are not particles in general, but they are metal balls.
Yes you were, because this is now a different problem than just using "particles".
You are careless once more, because the size of these "metal balls" should also be specified! Are they of the same size? Different?
Zz.
Same size. They are completely identical, the difference is just their charge.
The average cannot be because of charge conservation, already said. If you also intended to ask how the totale charge is shared into the final particles, theni t depends on a lot of different cases, for example: the first particle's charge is +1e (or -1e) ?
Then this (elementary) charge cannot divide in parts so the final particles cannot have fractionary charge: one of them must have +1e (-1e) charge and the other zero;
the first particle's charge is +ne (or -ne) n>1? Then the final particles can be both charged but the sum of their chsrges must be +ne(or - ne), etc;
the initial particles are elementary ones? Then their charge is fixed, they cannot have different charges (even if total charge conservation is respected).
Edit: I see now that the OP question has been refined.
lightarrow
I'm not sure why this isn't intuitively obvious to you. The "collision" part is irrelevant. This is high-school level static electricity problem.
When they touch, the charge will try to spread out as evenly as possible between the two metallic spheres. Because they are of identical size, no one sphere is more preferable than the other. This means that each sphere will have the same amount of charge. So when they separate, each sphere will carry half of the charge of original sphere. The two of them combined will carry the same amount of total charge as before.
Zz.
You made quite a mess: "particles" and then metal balls, "average charge": if you have two equal metal balls, why you didn't simply say "half of total charge on every ball"? :smile:
lightarrow
lightarrow
Yes, it made sense to me too, but this is part of a problem of a competition at my university and I was suspicious that it is too simple. Thank you for your help.
lightarrow
If the resulting two balls have different diameters then their relative capacitances would make the sharing unequal. The capacitance of a sphere is proportional to its Radius so the charges would be distributed proportionally to their radii. If one ball were twice the radius of the other, the original charge would be shared in the ratio 2:1
Likes Robin04
Sure. But in post #8 the OP stated "Same size. They are completely identical, the difference is just their charge."
Bye!
lightarrow
Bye!
lightarrow
Yes, that's right but the more general case is of interest and the result is pretty simple.
1. What happens when a charged particle collides with an uncharged particle?
When a charged particle collides with an uncharged particle, there are a few possible outcomes depending on the specific circumstances. If the charged particle is moving at a high enough speed, it may transfer some of its charge to the uncharged particle, causing it to become charged as well. Alternatively, the charged particle may simply bounce off of the uncharged particle without any significant interaction.
2. How do the charges of the particles affect the collision?
The charges of the particles involved in a collision play a significant role in determining the outcome. If both particles have the same charge, they will repel each other and likely not collide at all. If one particle is positively charged and the other is negatively charged, they will be attracted to each other and may collide. The relative strength of the charges also affects the force of the collision.
3. What factors influence the trajectory of the particles after the collision?
The trajectory of particles after a collision is influenced by several factors, including their masses, speeds, and charges. The angle at which they collide and any external forces present also play a role. Additionally, the type of interaction between the particles (e.g. elastic or inelastic) can affect their trajectories.
4. Can the collision of a charged and an uncharged particle produce new particles?
In certain collisions, the energy of the particles involved may be high enough to cause a transformation or decay, resulting in the production of new particles. This is commonly seen in particle accelerators, where charged particles are collided at extremely high speeds to create new particles for study.
5. What is the significance of studying collisions between charged and uncharged particles?
Studying collisions between charged and uncharged particles is crucial for understanding the fundamental principles of physics. These collisions can provide insights into the behavior of matter, the nature of forces and interactions, and the properties of particles. They also have practical applications in fields such as particle physics, nuclear energy, and medical imaging.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • High Energy, Nuclear, Particle Physics
