heartshapedbox
- 30
A particle of mass 5.0kg travels initially with a velocity of 8.0mˆı and then interacts with a particle of mass 6.0kg which was initially at rest. After the interaction the 5.0kg mass travels at a speed of 4.0m/s along a direction which makes an angle of 53◦ with the x-axis.
What is the change in momentum of the 5kg mass? -28i -16j
What is the speed of the 6kg mass after the interaction?
m1v1=(m1v2)f+m2v2
So I am thinking the momentum must be conserved. If the initial velocity was 8m/s in the i direction, the final velocity must be as well. The final velocity of the 5kg mass in component form is 4cos(307)=2.4i and 4sin(307)=-3.2j. This means the final velocity of the 6kg mass is 5.6i and 3.2j, giving 6.5 as the final velocity.
Apparently the answer is 5.4, can you show me what i should be doing instead. Thanks :)
