• Support PF! Buy your school textbooks, materials and every day products Here!
Collision question
  • Thread starter radagast_
http://img518.imageshack.us/img518/7105/76py8.gif [Broken]
I don't want a solution, just guidelines.. I don't really know how to approach it.
I was thinking about an equation of conservation of momentum which will give me 2 equations (x, y) and conservation of energy (because of the ellastic collision) which will give me another equation. All in all - 3 equations, but I have 4 variables: alpha, v0, and the ball and object's speeds after the collision.
What am I missing?
Thank you.
Answers and Replies
anyone? any clue will be helpful...
tiny-tim
25,832
249
Hint 1: What does "elastically" mean? What does that enable you to write?
Hint 2: There's also a force - the force from the wall. How can you keep that out of your calculations? :smile:
1. it means conservation of energy => it gives me an equation as I've written on the original post.
2. I know there's a force (normal?). that's my problem - combining it with the momentum equations. it's external, right? so there's no conservation of momentum. how can I put this in an equation?
thanx.
tiny-tim
25,832
249
Yes … but you've not actually written the equation …
Newton's second law: force = (rate of) change of momentum.
So you only get conservation of momentum when the force is zero.
But Newton's second law is three-dimensional: it's a different equation for every direction.
So can you see a direction in which there's zero force? :smile:
ok...
1.
ub=ball speed after
ut=table speed after
m(v0)^2=m(ub*cos(beta))^2+M(ut)^2
that's what I know.
There's a normal force from the table (because of the floor), right?
but how can I put the kinetic energy in an equation with the normal force?
tiny-tim
25,832
249
Take components along the slope
That's right - the "instantaneous" impulse from the table is perpendicular to it :smile:(but only, of course, because the question specifies that "there are no friction forces at all").
You're absolutely right! You can't! :smile:
But you can put the momentum in an equation with the normal force, provided that you do it only in the direction of the slope - because in that direction the component of the normal force is zero!
So … what is the momentum equation in the direction of the slope? :smile:
Im sorry, I don't understand: how can I put it with the normal force?
practically: the momentum is m*v (meter*kg/second) and the normal is (meter*kg/second^2)... I can't place them together in an equation...
tiny-tim
25,832
249
Good point … but collisions produce an impulse (an "instantaneous" force), which is force x time.
Just write out this (putting in the numbers):
and you'll see what I'm getting at. :smile:
well,
I get a component (cos(alpha) or cos(beta-alpha)) from every speed, v0, ub (ball after) and ut (table after)...
still three missing speeds (plus angle alpha) in one equation. I wrote it, I can't see what I can make out of it
tiny-tim
25,832
249
well,
Hi radagast!
Hint: what forces are on the block (the object)?
So which direction will it move in?
And does that help you with the momentum equation? :smile:
Hi radagast!
Thanks for the answers...
I'd appreciate it if you'd be more specific.. I am not following you.
Also, isn't there conservation of momentum on the x axis? how does that get along with the momentum parallel to the slope?
tiny-tim
25,832
249
There is conservation of momentum in every direction - the x-axis, the y-axis, along the slope, perpendicular to the slope …
We just choose whatever direction is easier - in this case, it's along-the-slope! :smile:
radagast, you keep not answering my questions.
That means I have no idea how far you're getting.
If someone on this forum helps you by asking a question, then you must answer it!
So … what forces are on the block?
ok.
The forces on the block are mg to -y^, and on the moment of the impact also normal perpendicular to the slope, right?
tiny-tim
25,832
249
Ignore gravity
ok.
hmm … I wish I'd called it the "hypotenuse" rather than the "slope". :redface:
I'm pretty sure the question intends you to ignore gravity - either x and y are coordinates on a smooth horizontal plane, or it's all in a "free-fall" frame in deep space.
Is that what was bothering you?
(This is a bad question - the examiner should specify things like that :frown:. Maybe the examiner thinks that the down direction is always called "z"?)
So, ignoring the mg, the only force is perpendicular to the hypotenuse, and so the block moves in that direction, and so its momentum along the hypotenuse is zero!
ok … so the momentum equation along the hypotenuse is … ? :smile:
tiny-tim
25,832
249
Ignore gravity
ok.
tiny-tim
25,832
249
Ignore gravity
ok.
tiny-tim
25,832
249
Ignore gravity
ok.
tiny-tim
25,832
249
ok.
tiny-tim
25,832
249
Ignore gravity
ok.
Well, the object isn't moving perpendicular to the force: the normal is at an angle (not 90) relative to the x axis, and the object's moving on the x axis.
the momentum equation is:
(a=alpha, b=beta, ub=ballspeed after, ut=tablespeed after)
m*v0*cos(a) = m*ub*cos(b-a) + M*ut*cos(a)
tiny-tim
25,832
249
I'm confused … because you're confused … :confused:
The object moves perpendicular to the hypotenuse - in other words, it moves along the normal - so how do you get it moving on the x-axis?
Try again! :smile:
Related Threads for: Collision question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
