Can Column Vectors be Multiplied?
In summary, the conversation discusses the relationship between the complex conjugate transpose of a vector and the operations of inner and outer product. It is confirmed that \mathbf{h}\mathbf{h}^* is the outer product of two vectors and \mathbf{h}^*\mathbf{h} is the inner product. The inner product is typically a real number, while the outer product has applications in dual vector spaces, including in quantum mechanics and general relativity.
EngWiPy
1,368
61
Hello,
Suppose that [tex]\mathbf{h}[/tex] is an [tex]N\times 1[/tex] column vector. Can we say that:
[tex]\mathbf{h}^*\mathbf{h}=\mathbf{h}\mathbf{h}^*[/tex]
where * means complex conjugate transpose?
Thanks in advance
Mathematics news on Phys.org
Try it out for yourself. Take [tex]\mathbf{h} = [1, 0]^*[/tex].
Furthermore, if you're not familiar with them, you may want to look up the terms inner product and outer product. They are operations on vectors that, conveniently, map to matrix multiplication between conjugate transposes.
Ok then, [tex]\mathbf{h}\mathbf{h}^*[/tex] is the outer product of the two vectors, and [tex]\mathbf{h}^*\mathbf{h}[/tex] is the inner product of them. Right?
Yup!
Usually, the inner product is taken to be a real number, not a 1x1 matrix. But the two ideas are identical. The inner product is well known for it's use is defining orthogonality and angles.
The outer product is less commonly known. It has applications when working with dual vector spaces. It's useful in QM and GR.
Tac-Tics said:
Yup!
Ok thank you Tac-Tics.
Best regards
What is a column vector product?
A column vector product is a type of mathematical operation that combines two or more column vectors to produce a new vector. It is also known as a dot product or inner product.
What is the formula for calculating a column vector product?
The formula for calculating a column vector product is:
c = aT * b = a1b1 + a2b2 + ... + anbn
What is the significance of the results of a column vector product?
The results of a column vector product can provide important information about the relationship between the two vectors being multiplied. The magnitude of the product can indicate the strength of the relationship, while the sign can indicate the direction.
How is a column vector product used in real-world applications?
Column vector products are commonly used in physics, engineering, and other scientific fields to calculate forces, work, and other important quantities. They can also be used in data analysis and machine learning to find patterns and relationships between variables.
What are some properties of column vector products?
Some properties of column vector products include distributivity, commutativity, and associativity. They also follow the laws of scalar multiplication and can be used to find the angle between two vectors.
  • General Math
  • Classical Physics
