Combinatorics Problem: Solving Geometric Angle Challenges with Addition
In summary, this conversation discusses the idea of combining two triangles to get different results, replacing triangles with the number 3 and using mathematical operations of addition. The conversation also explores a different approach to mathematics and the potential for practical applications. The concept of "addition" is redefined and the idea of overlapping two polygons is introduced. The conversation also delves into the relationship between natural geometric objects and real geometric objects in mathematics. The speaker presents various theorems and evidence to support their ideas, including the comparison of natural numbers and the concept of points in numbers.
ms.math
Watch the image below. If we combine the two triangles we get different results. Triangles will be replaced with the number 3 (because triangles have three angles), the results obtained with the number as a geometric object angles. Connecting the two triangles is the mathematical operations of addition
a + b = c
1.3 +3 = 3
2.3 +3 = 4
3.3 +3 = 5
4.3 +3 = 6
5.3 +3 = 7
6.3 +3 = 8
7.3 +3 = 9
8.3 +3 = 10
9.3 +3 = 12
The current mathematics has the answer (4.3 +3 = 6), it is impossible for the other, the reality is that this may be true.
I'll show you a review of mathematics that solves problems, join ...
Mathematics news on Phys.org
Yes, I see what you're doing. You're looking at all the different ways you can overlap two triangles to get various numbers of angles. I imagine there's some combinatorics going on. You could probably work out all the possibilities for overlapping any two polygons.
There's no contradiction between what you're doing and "current mathematics." Where are you going with this?
Yes. a(a>2)+b(b>2)=c -general form for all polygons
A different approach, a mathematical space that has two starting points (natural and realistic axiom - a natural geometric object and a real geometric object) in a mathematical space is monitored geometrical relationship between the object (function, numbers, logic equations, ..., are different names relations geometrical object).
Natural geometric object - along the natural (Figure AB)
point the natural properties of longer, its beginning (A) and end (B) - the current point math is not defined.
Natural longer merge points. Each new geometric object should come from natural and long previous geometrical object (this is achieved by association of concepts and new concepts not as an axiom by the current math).
The following post is made to demonstrate the first evidence
So you have redefined "addition". Nothing wrong with that as long as you understand that this is NOT "standard" addition and does not refute "standard" addition. And, in fact, it is pretty tame compared to general group theory.
Are you thinking there might be useful applications of this?
When you look at this "addition", you will not understand, because you need to show much new to you realize
1.3 + (.0)3 = 3
2.3 +(.1)3 = 4
3.3 +(.2)3 = 5
4.3+3 = 6
5.33Rd1(6)d2(7)+3 = 7
6.33Rd1(6)d2(8)+3 = 8
7.33Rd1(6)d2(9)+3 = 9
8.33Rd1(6)d2(10)+3 = 10
9.33Rd1(6)d2(12)+3 = 12
if you look at the history of mathematics, you will see that the new things in math should take some time to have a practical application
theorem - two (more) natural merge in the direction of longer AB
experiment (realization theorem)
http://docs.google.com/open?id=0BzkWG0xdRpPYdnh4SllhQkppVVU [Broken]
we get the following geometric objects
1. final (n, in Figure 1.2.3.) Along
2. infinite (n, in Figure 4.) along a one-way infinite
asking - can you repeat back the title "ms.math" ( instead of combinatorics problem )
Theorem - the length between points 0 and all points (separately) on the number the longer the new relationship
proof - look along the numerical
We got a set of natural numbers N = {0,1,2,3,4,5,6,7,8,9,10,11,12, ...},
example of the difference and the number of points on the number exceed:
Item 5 and No. 5 are two different things, point 5 is the point number 5 is the length between points 0 and 5 points along the numerical
2.4 Mobile Number
Theorem-Natural numbers can be specified and other numerical
point other than the point numeric 0th
Proof - Value (length) numeric point (0) and numeric item (2)
the number 2
Ratio (length) numeric point (1) and the numerical point of (3) is the number 2
Ratio (length) numeric point (2) and the numerical point of (4) is the number 2
2.5 Gap numbers
Theorem- number and mobile number of no contact, ( number and mobile number without contact) and mobile number without con-
clock, ..., in numeric longer.
EVIDENCE - number 2 and mobile number 2 no contact, gets
a gap of 2 (.1.) 2
number 2 and number mobile 2 no contact, getting the
2 (.2.) 2
number 2 and number mobile 2 no contact, getting the gap
2 (.3.) 2
(number 2 and mobile number 2 no contact) and mobile number 1
no contact, getting a gap of 2 (.1.) 2 (.1.) 1
https://docs.google.com/open?id=0BzkWG0xdRpPYcWYzN05RdGNvRnM
Gap set of numbers GN={ a |(.bn.)cn | (a, bn, cn)[itex]\in[/itex] N, bn> 0}
2.6 Moving of gap number
Theorem-gap numbers can be entered and the second numerical
EVIDENCE-ratio (length) numeric point (0) and the numerical point of (4) is
gap 2 (.1.) 1
Ratio (length) numeric point (1) and the numerical point of (5) is gap 2 (.1.) 1
Ratio (length) numeric point (2) and the numerical point of (6) is gap 2 (.1.) 1
2.7 Points of number
Theorem - Number of numeric longer has a point, it could be the opposite
write.
EVIDENCE - Number 5 has a point: (.0), (.1), (.2), (.3) (.4) (.5). Opposite may
write: (.. 0), (​​.. 1), (​​2 ..) (.. 3), (​​4 ..) (.. 5).
Emptiness 2 (.3.) 1 has a point: (.0), (.1), (.2), (.3) (.4) (.5), (.6). can
Write the opposite: (.0), (​​.. 1), (.. 2), (​​3 ..) (.. 4), (​​5 ..) (.. 6)
2.8 comparability of natural numbers
Theorem-Two (more) numbers are comparable to know
Who is the greater (equal, smaller), which is the point of (.. 0) away from the
numerical point of 0th
EVIDENCE - Two issues: 5> 3 (item number 5 (.5) away from the point
number 3 (.3)) 5 has a number of third 4 = 4 (item number 4 (.4) and the number of points
4 (.4) are equidistant) 4 is equal to 4 .2 <6 (item number 6 (.6) is
distance from point number 2 (.2) 2 less than 6 . ). (= {>, =, <}, a). (b.
Three issues: a). (b). (c
Hi, msmath, are you serious about any of the above? I find it all completely incoherent. Would you mind explaining in complete sentences what is going on, and what your motivation for this is?
Every new thing emerges from the previous, my terms are associated
2.9 Addition
Theorem-number (number of gaps) and mobile number (mobile Gap
number) are in contact, the movable point number (mobile number gaps)
(.0) Varies according to the number of counts (number of gaps) and connect.
EVIDENCE - 3 + (.0) 3 = 3 or 3 + (.. 3) = 3.
3 + (.1) 3 = 4 or 3 + (.. 2) = 4
3 + (.2) 3 = 5 or 3 + (.. 1) 3 = 5
3 + (.3) 3 = 6 or 3 + (.. 0) 3 = 6 or 3 +3 = 6
https://docs.google.com/open?id=0BzkWG0xdRpPYeDVhTlVzY20tZWM
With this solution we get the first 4 solutions, the other will have to wait!
You seem to be unwilling to answer our questions. This thread has degenerated in you talking to yourself. Locked.
1. What is combinatorics?
Combinatorics is a branch of mathematics that deals with counting and arranging objects or events. It involves studying different ways to select or group objects, as well as the patterns and relationships between them.
2. What is a combinatorics problem?
A combinatorics problem is a mathematical problem that involves counting or arranging objects or events. These problems can range from simple counting questions to more complex problems involving permutations, combinations, and other mathematical concepts.
3. How do you solve a combinatorics problem?
To solve a combinatorics problem, you need to identify the type of problem and then use appropriate counting techniques to find the total number of outcomes. This may involve using formulas, creating a table or tree diagram, or applying other mathematical principles.
4. What are some common types of combinatorics problems?
Some common types of combinatorics problems include permutations, combinations, and binomial coefficients. Other types of problems may involve organizing objects in a specific way, finding the number of possible outcomes in a game or experiment, or determining the number of ways to arrange objects in a line or circle.
5. Why is combinatorics important?
Combinatorics is important because it has many practical applications in fields such as computer science, statistics, and engineering. It also helps us understand and solve real-world problems involving counting and arranging objects or events. Additionally, combinatorics plays a crucial role in the development of new mathematical theories and techniques.
  • Science and Math Textbooks
  • General Math
  • General Math
  • Math Proof Training and Practice
  • General Math
