Combined thermal capacitance
In summary, the thermal capacitance of the beaker and water together can be calculated by adding the reciprocal of the individual thermal capacitances, with the correct units of J/(kg*K). This approach assumes no heat transfer between the beaker and water.
bertie
The mass of the water m_w in a beaker is 0.03988kg
the mass m_g of the glass the beaker is made of is 0.031kg
the specific heat c_p_g of the glass is 800 J/(kg*degrees C)
the specific heat c_p_w of the water is 4178 J/(kg*degrees C)
m_w*c_p_w = C_w where C_w is the thermal capacitance of the water
m_g*c_p_g = C_g where C_g is the thermal capacitance of the glass
What is the combined (lumped, if you will) thermal capacitance of the beaker and the water together?
Would it be C_combined^-1 = C_w^-1+C_g^-1 the way we would combine 2 electrical capacitors in series?
Thank you all!
I can confirm that your approach is correct. The thermal capacitance of the beaker and water together can be calculated by adding the reciprocal of the individual thermal capacitances. In other words, C_combined^-1 = C_w^-1 + C_g^-1. This is similar to how we combine electrical capacitors in series.
However, I would like to point out that the units for thermal capacitance are not in J/(kg*degrees C). The correct units for thermal capacitance are J/(kg*K), where K represents Kelvin, the SI unit for temperature. So, you would need to convert the temperature from degrees Celsius to Kelvin before calculating the thermal capacitance.
Also, keep in mind that this approach assumes that the beaker and water are in thermal equilibrium and there is no heat transfer between them. If there is heat transfer, the combined thermal capacitance will be different and would require a more complex calculation.
What is combined thermal capacitance?
Combined thermal capacitance is a measure of the combined thermal energy storage capacity of a material or system. It takes into account both the specific heat capacity and the thermal conductivity of the material.
How is combined thermal capacitance calculated?
To calculate combined thermal capacitance, the specific heat capacity and thermal conductivity of the material or system must be known. The formula is C = ρcK, where C is the combined thermal capacitance, ρ is the density, c is the specific heat capacity, and K is the thermal conductivity.
Why is combined thermal capacitance important?
Combined thermal capacitance is important because it determines the ability of a material or system to store and transfer thermal energy. A higher combined thermal capacitance means a material or system can store more thermal energy and release it more slowly, leading to better temperature regulation.
How does combined thermal capacitance differ from specific heat capacity?
Combined thermal capacitance takes into account both the specific heat capacity and thermal conductivity of a material or system, while specific heat capacity only considers the amount of heat required to raise the temperature of a material by a certain amount. Combined thermal capacitance is a more comprehensive measure of a material's thermal energy storage capacity.
What are some applications of combined thermal capacitance?
Combined thermal capacitance is used in various engineering and scientific fields, including building design, energy storage systems, and industrial processes. It is also important in the study of climate change and the Earth's thermal energy balance.
  • Electrical Engineering
