Homework Help: Combining lenses
  1. Nov 4, 2009 #1
    2 thin lenses separated by 10cm. First has a focal length of 20cm, the second has a focal length of 30cm.
    2. Relevant equations
    Lens transfer matrix for each lens:
    [tex]\begin{bmatrix}
    1-\frac{D_2d_{21}}{n_{t1}} &-D_1-D_2+\frac{D_1D_2d_{21}}{n_{t1}} \\
    \frac{d_{21}}{n_{t1}} & 1-\frac{D_2d_{21}}{n_{t1}}
    \end{bmatrix}[/tex]
    3. The attempt at a solution
    Since the thickness of the 2 lens is assumed to be zero we have:
    [tex]A_1=\begin{bmatrix}
    1 & \frac{-1}{f_1}\\
    0 & 1
    \end{bmatrix}[/tex]
    For the first lens and
    [tex]A_2=\begin{bmatrix}
    1 & \frac{-1}{f_2}\\
    0 & 1
    \end{bmatrix}[/tex]
    for the second. Therefore we have:
    [tex]A=A_2TA_1=A_2=\begin{bmatrix}
    0 & 1
    \end{bmatrix}\begin{bmatrix}
    1 & 0\\
    d & 1
    0 & 1
    \end{bmatrix}=\begin{bmatrix}
    1-\frac{d}{f_2} & \frac{-1}{f_1}-\frac{1}{f_2}+\frac{d}{f_1f_2}\\
    d & 1-\frac{d}{f_1}
    \frac{2}{3} & \frac{-1}{15}cm^{-1}\\
    10cm & \frac{1}{2}
    A_{11} & A_{12}\\
    A_{21} & A_{22}
    \end{bmatrix}[/tex]
    Since the system is assumed to be in air, the focal length is the same on both sides of the system. SO we have:
    [tex]f=\frac{1}{-A_{12}}=15cm[/tex]
    [tex]\overline{H_1O_1}=(1-A_{11})f=5cm[/tex]
    [tex]\overline{H_2O_2}=(1-A_{22})f=7.5cm[/tex]
    Where H denotes the principle planes and O denotes the lenses.
    So here's the problem, recall that the lenses are separated by only 10cm, this forces principle plane #2 to be in front (left of) principle plane #1. How can this be true? What did i do wrong?
Draft saved Draft deleted
