Combining sums problem
  1. Oct 3, 2010 #1
    I'm having some confusion about combining sums. Our goal when combining these sums is to have the,
    [tex](x-c)^{\text{whatever}}[/tex]
    term to be the same in both sums.
    My confusion is better explained in an example. (see below)
    2. Relevant equations
    3. The attempt at a solution
    Let's say we have the following 2 sums and we want to simplify them into one sum,
    [tex]\sum_{n=0}^{\infty} (-1)^{n}2^{n}nx^{n+1} + \sum_{n=0}^{\infty} (-1)^{n}2^{n}nx^{n-1}[/tex]
    As you can see the,
    terms are not identical, one is (n+1) and the other is (n-1).
    So if we wanted to make the two exponents identical for the first sum we would look as,
    [tex]n \rightarrow n-1[/tex],
    and plug in (n-1) where all the n's used to be in the first sum, and change the starting point of the sum to 1
    Now for the second sum, we would look as,
    [tex]n \rightarrow (n+1)[/tex],
    and plug in (n+1) where all the n's used to be in the second sum,
    ***Here's where I get confused***
    But my professor had mentioned to the class that this would not change the starting point of the sum to n= -1, it stays at n=0.
    Why is that? Can someone please clarify?
    Thanks again!
  3. Oct 3, 2010 #2
    Bump, still trying to figure this one out.
  4. Oct 3, 2010 #3
    [tex]
    \sum_{n=0}^{\infty} (-1)^{n}2^{n}nx^{n+1} + \sum_{n=0}^{\infty} (-1)^{n}2^{n}nx^{n-1} =
    [/tex]
    [tex]\sum_{n=0}^{\infty} (-1)^{n}2^{n}n\left(x^{n+1} + x^{n-1} \right) = \sum_{n=0}^{\infty} (-1)^{n}2^{n}nx^{n+1}\left(x^{-2}+1 \right) = \left(x^{-2}+1 \right) \sum_{n=0}^{\infty} (-1)^{n}2^{n}nx^{n+1} [/tex]
    Dunno what else to do..
  5. Oct 3, 2010 #4
    This doesn't really answer the question I had in the OP.
  6. Oct 3, 2010 #5
    Ok, then I don't know.
    Btw I don't even see any [tex] (x-c)^{\text{whatever}} [/tex] term in any of the sums unless you mean that c = 0. And I made it into one sum with one [tex] x^{\text{whatever}} [/tex] where whatever is a function of n.
  7. Oct 3, 2010 #6
    Ok. I think the reason it stays at zero is because when you replace n with n+1 and plugin n = -1 for the first term the term will be zero so it doesn't matter if you start your sum at 0 or -1, you will still get the same result.
  8. Oct 3, 2010 #7
    Can anyone else verify this? Is this actually why, or is it just a coincidence?
  9. Oct 3, 2010 #8
    Me again! ;)
    Well it works with all sums where the first term is zero which they are if you have a sum starting at n=0 of n*f(n,x) and f(n,x) is 'nice' in n=0.
