1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Comet Orbit
  1. Oct 23, 2016 #1
    Find maximum possible aphelion distance for a Kuiper Belt comet with an orbital period of 216 years?
    What is the eccentricity of this orbit?
    What prevents a periodic comet from following this precise orbit?
    2. Relevant equations
    perihelion = a(1-e)
    aphelion = a(1+e)
    2a = perihelion + aphelion
    3. The attempt at a solution
    (216)^2 = a^3
    a = 36 AU (semi major axis)
    From here, I'm not sure where to go because I don't know the eccentricity, perihelion or aphelion distance
  3. Oct 23, 2016 #2
    You've calculated the semi-major axis (I think correctly), and you are asked to find the maximum possible aphelion. What does maximum possible aphelion mean in terms of the perihelion? Is there a minimum possible perihelion that the object can have and still be a Kuiper belt object?
  4. Oct 23, 2016 #3
    Okay so since the aphelion is the point where the comet is furthest form the Sun, the max aphelion is 71.99 AU, and then I can calculate the eccentricity of the orbit
  5. Oct 23, 2016 #4
    How did you come up with the 71.99 AU number?
  6. Oct 23, 2016 #5
    The major axis is 72 au and the max distance that the comet can be from the Sun is some number very close to 72, such that the orbit goes very close to the Sun at perihelon and very far away at aphelion
    71.99 was just something I picked
  7. Oct 23, 2016 #6
    If it grazes the sun at perihelion, would it be considered a Kuiper belt object?
  8. Oct 23, 2016 #7
    No, I suppose it wouldn't
  9. Oct 23, 2016 #8
    Is the definition of a Kuiper Belt object that it lies between 40 and 50 AU from the Sun?
  10. Oct 23, 2016 #9
    • Please don't solve problems for others, that's against forum rules you agreed to when registering. Instead prod them in the right direction.
    Here are my thoughts:
    The inner edge of the Kuiper Belt is 30 AU, outer edge is 50 AU. Hence, the closest the comet's orbit can get to the Sun is 30 AU. This is our perihelion, because in order to maintain that the semi major axis is 36, and we want the maximum possible aphelion, we calculate with the minimum possible perihelion.
    So, we use the equation; semi major axis = (aphelion + perihelion)/2, giving us
    36= (A+30)/2
    The max possible aphelion is 42 AU.
  11. Oct 23, 2016 #10
    Thanks, this makes sense :)
    I am still wondering why this is not a valid orbit for a periodic comet
  12. Oct 23, 2016 #11
    Hmmm, well a short-period comet must have an orbit of 200 years, so perhaps the eccentricity should be lower in order for it to be a valid orbit for a short period comet? However, this doesn't tangibly prevent the comet from following this orbit so I am unsure.
  13. Oct 29, 2016 #12
    Staff: Mentor
    Sorry for the late reply, but I just noticed this thread. I don't often browse here.
    I think that's a clue that there's no restriction on the minimum perihelion distance for a comet. A comet is an object that passes through the inner solar system where it can be warmed by proximity to the Sun and rendered visible in our night sky. I believe that the designation of the comet as a "Kuiper Belt comet" refers to its place of origin, it being an object perturbed from the Kuiper belt. The aphelion of a periodic comet is a good indication of its origin distance.
    So your initial line of though regarding the orbit intersecting the Sun looks valid to me. Look up "degenerate ellipse" or "radial trajectory".
    Just because an orbit has a period it doesn't mean it will every have a chance to complete one :smile:
Have something to add?
Draft saved Draft deleted
Similar Threads - Comet Orbit Date
Orbitals S P D F Oct 20, 2016
Drawing Orbital overlap diagram for ammonia Oct 4, 2016
Organic Chemistry: Aromaticity Feb 22, 2015
