What is the slope of the common tangent line between two quadratic curves?
  • Thread starter Mr. Fest
  • Tags
    Tangent
In summary: P and Q is a common tangent to f(x) and g(x) iff that line is tangent to f(x) at P and tangent to g(x) at Q.In summary, a common tangent is a line that is a tangent to two curves. If point P is on curve f(x) and point Q is on curve g(x) then the line through P and Q is a common tangent to f(x) and g(x).
Mr. Fest
37
I don't quite understand the context of common tangent problems.
This is one of the problems I am trying to solve:
Prove that there is a line that is a common tangent to the parabolas y = x2 and y2 = x.
This is how I tried to solve it at least:
y2 = x --> y = [itex]\pm[/itex][itex]\sqrt{x}[/itex]
CASE I:
y = [itex]\sqrt{x}[/itex]
We have two derivatives:
One is: 2x
The other is: [itex]\frac{1}{2}[/itex]*[itex]x^{-1/2}[/itex]
Set these equal to each other and find that x = ([itex]\frac{1}{16}[/itex])[itex]^{1/3}[/itex]
--> The tangent has the slope [itex]\frac{1}{2^{1/3}}[/itex]
In this case, the tangents have the same slope for the same x-value --> It is NOT a common tangent.
CASE II:
y = -[itex]\sqrt{x}[/itex]
Here we have that the tangent of y = -[itex]\sqrt{x}[/itex] has the negative slope of [itex]\sqrt{x}[/itex] for the same x-value.
And for y = x2, the tangent has a same-value but negative slope for the negative x-value, that is y'(-x) = -y'(x)
In our case this gives us that:
The slope for y = -[itex]\sqrt{x}[/itex] at x = ([itex]\frac{1}{16}[/itex])[itex]^{1/3}[/itex] is -[itex]\frac{1}{2^{1/3}}[/itex] and the slope for y = x2 at x = -([itex]\frac{1}{16}[/itex])[itex]^{1/3}[/itex] is -[itex]\frac{1}{2^{1/3}}[/itex].
Therefore, there is a line that is a common tangent for y = x2 and y2 = x
Is this, the correct way to solve this problem or would you suggest some other way that is appliable for other problems of this sorts where you have to find common tangents...
Thanks a whole lot in advance.
Mr. Fest
To understand the methods, you have to start from the definition of "common tangent" ... how do you tell when the definition has been met?
It also helps to sketch the curves in question.
... they have the same x value - but, presumably, not the same y value?
This sounds tedious.
I think an all-in-one approach would be to find the equation of the line that is tangent to curve A at some point P and then find the point of intersection of that line with curve B ... call it Q. If PQ is a tangent to curve B, then you have found your common tangent.
This approach can be used to construct an equation for the conditions that a particular point P lies on a common tangent.
In your problems, no context has been supplied so there is nothing to understand about the context.
This is a common situation in pure mathematics.
Common tangent would be when two functions have the same slope for two different points (two different x-values), correct?
Exactly, they do not have the same y-value.
Would you care to elaborate? I think I understand what you mean. Are you telling me that I should for example for function A put the slope as (f(x)-f(a))/(x-a) and the actually calculate the derivative for the other function. Then set (f(x)-f(a))/(x-a) = derivative of the other function? (This presuming that we have gotten info for some specific points...)
Am I correct in my ideas of the common tangent problem or am I completely off? Would appreciate any further help.
Almost ... recall that a tangent is a line. It is possible for two different tangent lines to have the same slope. You are looking for the tangent line or lines that the two curves have in common: i.e. the tangent off one curve is also a tangent off the other one.
If point P is on curve f(x) and point Q is on curve g(x) then:
... the line through P and Q is a common tangent to f(x) and g(x) iff that line is tangent to f(x) at P and tangent to g(x) at Q.
You can see it clearly in the case of two circles: draw two circles ... now find all the straight lines that touch both circles at only one point each. There's four. Those lines are common tangents.
Now I understand it better, thank you.
I still find a bit troublesome to actually know how to find these points... because this means that the f'(x) = g'(x) but for different x-values. How can we find these different x-values?
This might sound stupid, but drawing two circles I only find two lines that touch both circles at only one point each. Namely, one above and one under the circles.
Two different points on a line.
It helps to sketch the situation so you know whereabouts to expect to find the solutions.
Note - P and Q can have the same x values if the curves happen to coincide at that point (i.e. P=Q)
i.e. f(x)=x^2 and g(x)=x^3 have a common tangent at x=0.
More generally:
http://www.math.washington.edu/~aloveles/Math124Fall2011/ConroytangentLines01.pdf
If the circles themselves are not touching or intersecting, then the other two common tangents form an X shape between them ;)
If the circles are not touching or intersecting, then the other two common tangents form a X shape between them ;)
Haha that is very true.
Thank you very much for your help. Have an exam tomorrow and I'm at work at the moment. But will definitely revise when I get home.
I modified post #6 to link you to a paper explaining how to find common tangents between quadratics.
The approach should help you figure it out for other functions too - but afaik there is no universal formula for finding them, which is why these puzzles are good tests of your mathematical ability.
In general you have to be prepared to play around a bit - and sketching the functions out is an essential skill.
Thanks a lot! :)
Re. your original problem.
Carefully sketch both curves on the same axes - one is a quadratic in x and the other a quadratic in y.
... using a ruler, find the common tangent line between the two curves: draw that line on your diagram.
... looking at that line - what does it's slope have to be?
1. What is a common tangent problem?
A common tangent problem is a geometric problem in which two circles or curves intersect, and the goal is to find the line that is tangent to both circles or curves at the point of intersection.
2. How many common tangents can two circles have?
Two circles can have up to four common tangents, depending on their sizes and positions relative to each other. They can have two external common tangents and two internal common tangents.
3. How do you solve a common tangent problem?
To solve a common tangent problem, you can use the formula for finding the distance between a point and a line. You can also use the equation for finding the slope of a line tangent to a circle at a given point. Then, setting these two equations equal to each other and solving for the point of intersection will give you the coordinates of the tangent point. Finally, using the slope and point, you can find the equation of the tangent line.
4. What are some real-world applications of common tangent problems?
Common tangent problems have many real-world applications, such as in engineering, physics, and architecture. They can be used to find the point of tangency between two gears, the angle of incidence between a light ray and a curved mirror, and the optimal path for a racecar around a curved track.
5. Are there any special cases in common tangent problems?
Yes, there are two special cases in common tangent problems: when the two circles or curves are tangent to each other, and when one circle is inside the other. In these cases, the number of common tangents reduces to one and zero, respectively.
  • Calculus
  • Calculus
