Homework Help: Communication question
  1. May 6, 2010 #1
    Hi there,
    This is my first post so I hope that I am doing this correctly. I have put the question below and i am having troubles with numbers 3,5 and 6. Any help would be great.
    Cheers
    A transmitter with an output power of 200W operates at a frequency of 20MHz. It feed an antenna with an impedance of 30 Ω. The cable has a characteristic impedance of 50 Ω and a velocity factor of .90. Cable loss will be ignored and power rating is adequate for the application.
    Load is not matched to the transmission line so there will be some reflection of the incident wave energy when it arrives at the load. The incident wave and the reflected wave will both combine to produce an interference phenomenon known as a stationary wave or standing wave.
    1. Calculation the Reflection Coefficient at the load
    Г = (Rl-Zo)/(Rl+Zo)
    Г = (30-50)/(30+50) = 20/80 =1/4 or 0.25
    * How do you convert this to dB??
    2. What does the sign mean of the reflection coefficient value
    +ve Maximum positive reflection when the line is open circuited
    -ve Maximum negative reflection when the line is short circuited
    0= perfectly matched
    3. Would there be a Maximum or Minimum in the standing wave
    4. Calculate the voltage standing wave ratio (VSWR) on the line
    VSWR = Zo/Rl = 50/30 = 1.6667
    VSWR = (1+ Г)/(1- Г) = (1+0.25) / (1-0.25) = 1.6667
    5. What is the distance between adjacent minima in the standing wave pattern.
    6. Calculate the actual amount of reflected power and the actual amount of power few to the load.
    Г^2 = Pref/Pinc
  3. May 6, 2010 #2
    berkeman
    Staff: Mentor
    Welcome to the PF. You have a sign error in #1, which affects your answer in #4. What is the range of values for VSWR? Knowing that, you should have caught the error in #4 right away.
    And in #1, you could have caught the sign error as well. When you have a load with a lower impedance than the transmission line that feeds it, do you get a postive or negative reflection?
  4. May 7, 2010 #3
    Hi Berkeman,
    Thanks for the info, I missed that sign error in the first post. I have since re-worked the question and found that the Г to equal -4
    Г = (Rl-Zo)/(Rl+Zo)
    Г = (-30-50)/(-30+50) = -80/20 = -4
    Does the max and min refer to the VSWR which has been worked out to be
    VSWR = -3/5 = -0.6
    So the max = -3
    and the min = 5
    VSWR = Zo/Rl = 50/30 = 1.66667
    VSWR = (1+ Г)/(1- Г) = (1+(-4)) / (1-(-4)) = -0.6
    * If I use both the VSWR equations how come I get two different answers, I am only assume that i have done something incorrect.
    *From the VSWR would this equal -0.6 ??
    * Do i use the Г value and sub into this formula
    Г^2 = Pref/Pinc and use the 200W given in the question?
    Thanks for your help
  5. May 7, 2010 #4
    berkeman
    Staff: Mentor
    AFAIK, there is no such thing as a negative VSWR. Look at the definition of [tex]\rho[/tex] at this wikipedia page (note the page has some math formatting issues at the moment...):
    http://en.wikipedia.org/wiki/VSWR
