I Communication with a Rindler observer
765
35
Is it possible that some light signals will never reach the Rindler observer?
Just to be clear, by Rindler observer I mean an observer undergoing constant acceleration (as measured in his own rest frame).
28,141
4,531
Yes. There is a "Rindler horizon" and any light signals emitted beyond the horizon will never reach the Rindler observer.
Edit: @haushofer for the win!
765
35
Wel, yes, that's the idea of a Rindler horizon, right? :)
so this Rindler observer is a great example of an "object" travelling slower than light and that is still "disconnected" from part of the universe?
haushofer
Insights Author
2,218
558
Yes. You don't need a black hole to obtain event horizons. And given the fact that locally an acceleration is indistinguishable from gravity, this shouldn't surprise you too much. But a Rindler observer can always decelerate to a constant speed such that his horizon disappears. The horizon of a black hole is truly a geometric property of spacetime.
haushofer
Insights Author
2,218
558
Sorry, was annoying other people in the GR-forum about questions concerning Lie derivatives, so was already here :P
28,141
4,531
No need to apologize. Hearing the same answer from multiple sources adds confidence in the answer
127
28
Tiny nitpick: the Rindler observer wouldn’t have to decelerate—she would just have to cut her engines to become an inertial observer with no horizon.
26,240
6,860
Yes, you do. The Rindler horizon is not an event horizon. Light signals emitted from behind the Rindler horizon can still reach infinity (more precisely, future null infinity); they just will never reach the Rindler observer.
765
35
Now thats confusing. If they do reach infinity, they should reach the Rindler observer, since the observer must be somewhere between a given point and "the infinity".
26,240
6,860
No, they don't. Both statements (that the light signals do reach infinity, and that they don't reach the Rindler observer) should be obvious from looking at a spacetime diagram, such as the one here:
The Rindler observer always stays within the right "wedge" shown in the diagram. A light signal emitted from behind the horizon is emitted from above and to the left of the 45 degree line that is the upper boundary of the wedge, and travels on a 45 degree line up and to the right (i.e., parallel to the boundary line). Obviously, such a line cannot reach the Rindler observer (since it never crosses the boundary, being parallel to it), and obviously it does reach infinity, since it keeps on going up and to the right indefinitely.
The misconception you probably have here is that "infinity" is a single point. It isn't.
28,141
4,531
No. The Rindler observer also reaches infinity and gets there first.
26,240
6,860
This assumes that "infinity" is a single point. It isn't.
A more technically precise way of stating it would be that the Rindler observer ends up at a point on future null infinity that is earlier (i.e., further away from future timelike infinity) than the point on future null infinity where the light ray emitted from behind the Rindler horizon ends up. (The point on future null infinity where the Rindler observer ends up is the same as the point where the Rindler horizon ends up.)
28,141
4,531
It doesn’t assume that. The phrase “reach infinity” is yours. I wouldn’t have chosen it precisely for the confusion it engendered in the OP and now apparently in yourself. In the sense that, as you said, the light reaches infinity, the observer reaches it first. I.e. in the limit the observer still always remains ahead of the light.
26,240
6,860
As I originally used it, I immediately qualified it with:
That was intended by me to make clear that "infinity" as I was using the term was not a single point. But I probably should have accompanied that with an explanation of what "future null infinity" actually is, or given a reference like the following:
This article calls it "lightlike infinity" but it's the same thing.
But the places they "reach" are not the same point. They are different points along the future null infinity line. Note that I also qualified "earlier" when I used it:
haushofer
Insights Author
2,218
558
Ok, maybe I'm sloppy with terms.
28,141
4,531
The problem with "reach infinity" is not the "infinity" part but the "reach" part. The fact that it is not a single point is not an issue. Delaware is also not a single point, but I can "reach" Delaware in a way that I cannot "reach" infinity.
In any case, I am kind of irritated for you to correct me on sloppy terminology that was introduced by you in the first place.
26,240
6,860
In the sense that "infinity" is not actually part of spacetime and nothing can ever reach it, sure, I agree. However, please bear in mind that the original reason I introduced the term "infinity" was to correct @haushofer's statement about the Rindler horizon being an event horizon. Without a definition of future null infinity and what it means for light signals to reach it, we cannot define what an event horizon is.
I apologize for that. I didn't realize when I corrected @haushofer that what I said would naturally seem confusing to the OP and would cause further problems. I should have introduced the more precise terminology earlier.
Want to reply to this thread?
"Communication with a Rindler observer" You must log in or register to reply here.
Related Threads for: Communication with a Rindler observer
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
