Prove Commutation Property for 2x2 Matrices D
In summary, the conversation discusses the commutativity of a 2x2 matrix D with all other 2x2 matrices. It is proven that D commutes with all other matrices if and only if d12 = d21 = 0 and d11 = d22. One method suggested is to try particular matrices, such as A = [0 1; 0 0], to see where it leads. It is also mentioned that the matrices [1 0; 0 0], [0 1; 0 0], [0 0; 1 0], and [0 0; 0 1] form a basis for the vector space of all 2x2 matrices,
vdgreat
Let D =
[d11 d12]
[d21 d22]
be a 2x2 matrix. Prove that D commutes with all other 2x2
I know if we can prove for every A, AD=DA should be true, but I really don't know how to proceed from there. I tried equating elements of AD with DA but that really didnt help.
Can anyone help me with this problem. Thanks..
Try particular As, like
[tex]A = \left(\begin{array}{cc} 0 & 1 \\ 0 & 0\end{array}\right),[/tex]
and see where that leads you.
morphism's idea is excellent. Do you see where he got it?
The matrices
[tex]\left(\begin{array}{cc}1 & 0 \\ 0 & 0 \end{array}\right)[/tex]
[tex]\left(\begin{array}{cc}0 & 1 \\ 0 & 0 \end{array}\right)[/tex]
[tex]\left(\begin{array}{cc}0 & 0 \\ 1 & 0 \end{array}\right)[/tex]
[tex]\left(\begin{array}{cc}0 & 0 \\ 0 & 1 \end{array}\right)[/tex]
form a basis for the vector space of all 2 by 2 matrices. What is true for the basis is true for all 2 by 2 matrices.
but how can i prove it or generalize it??
help with this problem
anyone?
Did you think about what has been posted already?
Which of the basis matrices I gave commute with all other matrices?
try to look over schur lemma... it is a generalztion of what you asked...
ciao
marco
for each of the above matrices, i found out that it is true. but how can i prove this without having knowledge of basis. i haven't don't it yet.
i got it thanks
What is the Commutation Property for 2x2 Matrices?
The Commutation Property for 2x2 Matrices states that the order in which two matrices are multiplied does not affect the result, as long as the matrices are square and of the same size.
Why is it important to prove the Commutation Property for 2x2 Matrices?
Proving the Commutation Property for 2x2 Matrices is important because it allows us to simplify calculations and manipulate matrices in different ways without changing the result. This property is also essential in various fields such as physics, engineering, and computer science.
How do you prove the Commutation Property for 2x2 Matrices?
The Commutation Property for 2x2 Matrices can be proven by using the definition of matrix multiplication and the properties of real numbers. We need to show that (AB) = (BA) for any two 2x2 matrices A and B. This can be done by expanding the matrices and rearranging terms to show that they are equal.
What are the steps to prove the Commutation Property for 2x2 Matrices?
The steps to prove the Commutation Property for 2x2 Matrices are as follows:
1. Start with two 2x2 matrices A and B.
2. Write out the definition of matrix multiplication (AB).
3. Expand the matrices and rearrange terms.
4. Use the properties of real numbers to simplify the expression.
5. Repeat the same steps for (BA).
6. Show that (AB) = (BA) by equating the two expressions.
7. Therefore, the Commutation Property for 2x2 Matrices is proven.
Can the Commutation Property be extended to matrices of any size?
No, the Commutation Property only applies to square matrices of the same size. For matrices of different sizes, the order of multiplication does affect the result. However, the Commutation Property can be extended to non-square matrices if they are both symmetric or both skew-symmetric.
  • Linear and Abstract Algebra
