Homework Help: Complete Metric Subspaces
  1. Feb 26, 2010 #1
    Determine whether the following metric subspaces are complete:
    a) the set E of sequences containing only entries 0 & 1 in [tex](m,||\cdot||_{\infty})[/tex]
    b) the unit sphere in any Banach Space
    2. Relevant equations
    a) for [tex]x=\{\lambda_1,\lambda_2,\ldots,\lambda_n,\ldots \}[/tex]
    [tex]||x||_{\infty}=sup\{|\lambda_n|:n=1,2,\ldots\}[/tex]
    b)[tex]\{x\in X:||x-x_0||=1\}[/tex]
    3. The attempt at a solution
    I think:
    A complete space is one in which all Cauchy sequences converges to a sequence (of points) in the space
    a) it seems that if I construct whatever sequence I construct will always have zeros, but my limit will be a sequence of only 1's, so it will not be in the space.
    That is, [tex]||x||_{\infty}=sup\{|\lambda_n|:n=1,2,\ldots\}=1[/tex]
    If this is correct, how do I show that?
    b) It seems this space is complete by the same reasoning above, but again, how do I show that?
  3. Feb 26, 2010 #2
    Dick
    You are thinking about the space E wrong. Your sequence is a single point in E. To discuss convergence you need a sequence of points in E, i.e. a sequence of sequences.
  4. Feb 26, 2010 #3
    I was thinking of:
    [tex]x_1=(1,0,\ldots) [/tex]
    [tex]x_2=(1,1,0,\ldots) [/tex]
    [tex]\vdots [/tex]
    [tex]x_n=(1,1,\ldots,1,0,\ldots)[/tex]
  5. Feb 26, 2010 #4
    Dick
    Is that Cauchy?
  6. Feb 26, 2010 #5
    I don't think so, since it doesn't have the property:
    [tex]|x_n-x_{n+1}|\rightarrow0 \text{ as }n\rightarrow\infty[/tex]
  7. Feb 26, 2010 #6
    Dick
    Right. It's not. Look at the definition of Cauchy in terms of epsilon and think about what happens if you put epsilon=1/2.
  8. Feb 26, 2010 #7
    That would mean:
    [tex]||x_n-x_m||_{\infty}<\epsilon=1/2[/tex]
  9. Feb 26, 2010 #8
    I'm still confused, and we haven't even started talking about B yet.
    known knowns:
    [tex](m,||\cdot||_{\infty})[/tex] is complete since it contains all bounded sequences.
  10. Feb 26, 2010 #9
    Dick
    If x_n and x_m are in E and |x_n-x_m|<1/2, doesn't that mean x_n=x_m?
  11. Feb 26, 2010 #10
    Yes it does. So, are you saying that my sequence I thought of is not in E or that it's in E and E it's not Cauchy so therefore E is not complete?
  12. Feb 26, 2010 #11
    Dick
    Your sequence is in E. But it's not Cauchy and it doesn't converge. So it doesn't tell you anything about whether E is complete or not. Having thought about the epsilon=1/2 thing, if {a_n} is a Cauchy sequence in E, what can you say about the sequence?
  13. Feb 26, 2010 #12
    You can say that [tex]||a_n-a_m||_{\infty}<\epsilon[/tex] is true
  14. Feb 26, 2010 #13
    Dick
    Apply what we decided in posts 9 and 10 to that.
  15. Feb 26, 2010 #14
    I don't understand where you are heading with this. Are you saying that we cannot construct a Cauchy sequence in E?
  16. Feb 26, 2010 #15
    Dick
    No. I'm saying if you put the definition of a Cauchy sequence together with the fact that "if |x_n-x_m|<1/2 then x_n=x_m", then it's easy to show all Cauchy sequences converge. Look up the definition of Cauchy sequence again and think about that.
  17. Feb 26, 2010 #16
    In this case:
    A sequence [tex]x_n[/tex] in [tex]\left(X,||\cdot||_{\infty}\right)[/tex] is Cauchy iff
    [tex]\forall \epsilon >0\quad \exists N\quad \ni \quad ||x_n-x_m||_{\infty}<\epsilon \quad \forall m,n\geq N [/tex]
    You are saying if we let [tex]\epsilon = 1/2 [/tex] then:
    [tex]||x_n-x_m||_{\infty}<1/2 \quad \Rightarrow \quad x_n=x_m[/tex]
    So, what insight is this providing in E (the set of sequences containing only entries 0 & 1)?
  18. Feb 26, 2010 #17
    In this case:
  19. Feb 26, 2010 #18
    Dick
    Ok, so that says that if {x_n} is Cauchy, then there exists an N such that for all n,m>N, x_n and x_m are the SAME SEQUENCE. Doesn't it?? The sequence {x_n} has to eventually be constant. Call that constant sequence 'c'. What's the limit of the sequence {x_n}??
  20. Feb 26, 2010 #19
    It would be the sequence containing only "c"?
  21. Feb 26, 2010 #20
    Dick
    Hmmm. I'm not sure what that means. I don't think I'm getting through. All of the elements in the sequence {x_n} are equal to x_(N+1) for n>N, right?
  22. Feb 26, 2010 #21
    That is my understanding
  23. Feb 26, 2010 #22
    Dick
    Ok, so doesn't the sequence have a limit?? And isn't that limit x_(N+1)?? What does that tell you about completeness?
  24. Feb 26, 2010 #23
    Are you saying that every sequence in E is it's own limit and that since any sequence I construct in E will be it's own limit then E is complete?
  25. Feb 26, 2010 #24
    Dick
    That sounds pretty garbled again. Remember a single sequence x_n is a POINT in E. The sort of sequences you need to talk about for convergence are sequences of sequences {x_n}. Got that? {x_n} is a whole bunch of sequences.
  26. Feb 26, 2010 #25
    You're right, I am having a hard time understanding sequences in E. Can you give me an example.
    See in [tex]E_o[/tex] (the set of all sequences with a finite number of non-zero terms) an example would be:
    [tex]x_1=(1,0,\ldots)[/tex]
    [tex]x_2=(1,\frac{1}{2},\ldots)[/tex]
    [tex]x_n=(1,\frac{1}{2},\ldots, \frac{1}{n},\ldots)[/tex]
    This sequence converges to
    [tex]x=(1,\frac{1}{2},\ldots)[/tex]
    and I understand this sequence is not a part of [tex]E_o[/tex]
    Therefore, [tex]E_o[/tex] is not complete.
    I am not understanding the argument in this space E
