Completely lost on oscillations problem
Two springs are joined and connected to a mass m such that they are all in a straight line. The two springs are connected first and then the mass last so that all three are in a row. If the springs have a stiffness of k1 and then k2, find the frequency of oscillation of m.
[itex] T = 2 \pi \sqrt{\frac{m}{k}} [/itex]
so i tried making an F=ma for the mass and spring 1 (which is said was the spring closer to the mass)...
F=ma system mass
[itex] F_{el} = ma [/itex]
[itex] k_1 x_1 = ma [/itex]
max acceration happens at aplitude:
[itex] k_1 x_1 = mA \omega ^2 [/itex]
F=ma system spring 1.
[itex] F_{el mass} - F _{el 2} = M_{s1} [/itex]
i am assuming the spring is massless ( i think we can do that)
so [itex] F_{elmass} = F_{el 2} [itex]
[itex] k_1 x_1 = k_2 x_2 [/itex]
i suppose [itex] x_1 + x_2 = A [/itex] when both x's are at maximum. ...
so [itex] \frac {k_1}{k_1} = k_2 (A-x_1) [/itex]
[itex] x_1 = \frac {A}{ \frac {k_1}{k_2} + 1 } [/itex]
go back the the last equation we got in f=ma system mass and subtitute in the x_1 we just found....
the A's cancel out and after we simply we get:
[itex] \omega = \sqrt{ \frac{k_1 k_2}{ (k_1 + k_1) m }} [/itex] ////
and to get F... just divide it by 2pi... right?
is this even correct?
Answers and Replies
try it with energy method you would be albe to solve it. if not reply i will post the solution.
SammyS
Staff Emeritus
1,007
Be careful about this in the homework section of PF !
do you see a problem with my solution?
SammyS
Staff Emeritus
1,007
F=ma system mass
toesockshoe,
I haven't examined your entire solution, but I'm pretty sure that your final answer IS correct !
Two springs connected in that manner have an effective spring constant of ##\displaystyle\ k_\text{eff}=\frac{k_1\,k_2}{k_1+k_2}\ .##
Related Threads on Completely lost on oscillations problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
