Complex analysis - integrals
In summary, complex analysis is a branch of mathematics that uses techniques from calculus to study functions of complex numbers. A real integral deals with functions of a real variable, while a complex integral deals with functions of a complex variable. The Cauchy integral theorem states that the value of the integral around a closed contour is zero for an analytic function. The Cauchy integral formula extends this to calculate the value of the integral at a point inside the contour. The Residue Theorem is a powerful tool that uses the residues of a function to calculate complex integrals around a closed contour.
Anabelle37
39
Evaluate the integral with respect to x from 0 to infinity when the integrand is x^2/(1+x^6), using complex integration techniques.
I have no idea where to start. Please help!
how about thinking about the poles of the function and considering contour integration?
1. What is complex analysis?
Complex analysis is a branch of mathematics that deals with the study of functions of complex numbers. It involves the use of techniques from calculus, such as differentiation and integration, to analyze and understand the properties of complex functions.
2. What is the difference between a real and a complex integral?
A real integral deals with functions of a real variable, while a complex integral deals with functions of a complex variable. This means that in a complex integral, the independent variable can take on complex values, whereas in a real integral, the independent variable can only take on real values.
3. What is the Cauchy integral theorem?
The Cauchy integral theorem states that for a function that is analytic (has a derivative) on a closed contour, the value of the integral around that contour is equal to zero. This means that the integral of an analytic function over a closed loop is independent of the path taken along the loop.
4. What is the Cauchy integral formula?
The Cauchy integral formula is an extension of the Cauchy integral theorem, which states that for an analytic function, the value of the integral is equal to the value of the function at a point inside the contour, multiplied by the number of times the contour winds around that point in a counterclockwise direction.
5. What is the Residue Theorem?
The Residue Theorem is a powerful tool in complex analysis that allows for the calculation of complex integrals by using the residues (singularities) of a function. It states that the value of an integral around a closed contour is equal to the sum of the residues of the function inside the contour.
