Complex Analysis question
  1. Oct 23, 2007 #1
    f:Complex Plane ->Complex Plane by f(z) = (e^z - z^e)/(z^3-1) continuous? (Hint: it
    has more than one discontinuity.)
    3. The attempt at a solution
    My attempt at a solution was thus, initially I expanded z^3 and tried to find where it equaled 1. That wasn't very straightforward, and then I figured I could just say the function is discontinuous when z^3 = 1, but I really don't think that's sufficient. Is there something I'm missing here?
    Thanks in advance.
  3. Oct 23, 2007 #2
    Dick
    z^e is not terribly well defined either. It's e^(log(z)*e) and log(z) has branches.
  4. Oct 23, 2007 #3
    Well, if z^e isn't continuous is that really a problem? I thought that things in the numerator weren't really an issue when dealing with continuity.
  5. Oct 23, 2007 #4
    Are you familiar with the nth "roots of unity"?
  6. Oct 23, 2007 #5
    Dick
    Not true. A discontinuous numerator is just as bad as a zero in the denominator.
  7. Oct 23, 2007 #6
    No. I'll wiki this, but I'd be interested in your explanation as well.
    Really. So z^3 = 1 wouldn't be so bad, I'd just have to find discontinuities in e^z and z^e then?
    EDIT: After reading about the nth roots of unity I could provide them for z^3 = 1. They're given on the wiki entry( http://en.wikipedia.org/wiki/Roots_of_unity )
  8. Oct 23, 2007 #7
    Dick
    No, z^3=1 is bad too. That's three discontinuous points. e^z doesn't have any. log(z) has a whole line of discontinuities. So that goes for z^e as well.
  9. Oct 23, 2007 #8
    What I meant was showing the discontinuities of z^3 = 1 wouldn't be too bad. Sorry about the misunderstanding.
  10. Oct 23, 2007 #9
    Also, Dick, is there somewhere I can read up on z^e? Why it's defined the way you say it is, etc.
  11. Oct 23, 2007 #10
    Dick
    There's no other way to define it. z=e^(log(z)) so z^e=e^(log(z)*e). But there is no continuous definition of log(z) in the whole complex plane. You have to remove part of the domain to get a continuous function. Look up "branch cuts". It's not just z^e. sqrt(z) has a very similar problem.
  12. Oct 24, 2007 #11
    HallsofIvy
    What exactly is the question? It appears to ask whether or not the function is continuous but then immediately tells you that it is not! Is the problem to find the points of discontinuity?
  13. Oct 24, 2007 #12
    generally the numerator also matters..for example. Sinz/z doesn't REALLY have a discontinuity at the origin (i.e the origin is NOT a pole) whereas 1/z DOES have a legitimate discontinuity at the origin(it's a simple pole).
    you need to understand the concept of branch cuts. also computing complex roots (wen the numbers are simple of course) is straightforward and can and probably should be done by hand.
Similar Discussions: Complex Analysis question
Loading...
