Contour Deformation and Jordan's Lemma in Complex Analysis
In summary, Jordan's lemma states that the integral over a complex path is zero if and only if the path encloses all the poles.
HasuChObe
31
Lets say you're doing one of those integrals from -\infty to \infty on the real axis and you chose to do it by contour integration. Let's say your integral is one of those integrals that's resolved by using Jordan's lemma. If you close the contour by making a giant loop such that Jordan's lemma holds, then you've established that the entire contribution to the integral is due solely to the integration over the real axis, which is equal to the sum of the residues enclosed.
Since you now know the entirety of the integral comes from integration over the real axis, can you arbitrarily deform the contour that's supposed to close over infinity to something arbitrary and still get zero contribution from the part of the contour that's not the real axis? This would be better with pictures, but hopefully you can understand what I'm asking.
I'm under the assumption that the integral over the real axis does not change its value depending on how you modify the part of the contour that's not on the real axis. This would imply that no matter how you deformed that part of the contour, its contribution remains zero. However, I'm looking at these things called Sommerfeld integration paths (electromagnetics) that would seem to suggest otherwise.
Assuming you don't pass over any poles, if you deform a path in the complex plane you don't change the integral over that path.
You can check this in total generality - if you have a holomorphic function f in some region, and a path gamma, pick a new path beta whose endpoints are the same as gamma. Since the integral going up gamma and down beta is zero, the integral going up gamma and the integral going up beta must be equal.
However if there are poles in between your old and new contour this obviously isn't true anymore.
So, assuming that the contour in the complex plane encloses all the poles, does Jordan's lemma basically say that the integral in the complex plane is always zero (provided that you start at one of the real infinities and end at the other)?
1. What is complex analysis?
Complex analysis is a branch of mathematics that deals with the study of functions of complex numbers. It involves the analysis of the behavior and properties of functions that are defined on the complex plane.
2. What are complex numbers?
Complex numbers are numbers that consist of a real part and an imaginary part. They are written in the form a + bi, where a and b are real numbers and i is the imaginary unit, defined as the square root of -1.
3. What are the applications of complex analysis?
Complex analysis has many applications in various fields such as physics, engineering, and economics. It is used to solve problems involving electric circuits, fluid dynamics, and signal processing, among others.
4. What is the difference between real analysis and complex analysis?
The main difference between real analysis and complex analysis is that real analysis deals with real-valued functions, while complex analysis deals with complex-valued functions. Complex analysis also has additional tools and techniques specific to the study of complex numbers.
5. What are some common techniques used in complex analysis?
Some common techniques used in complex analysis include Cauchy's integral theorem and formula, Laurent series, and residue theorem. These techniques are used to evaluate complex integrals, find the poles and zeros of functions, and solve boundary value problems, among other applications.
  • Topology and Analysis
  • Calculus
  • Quantum Physics
  • General Math
