Complex Analysis questions
  • Thread starter d3nat
d3nat
102
Laurent series
##f(z) = sinh(z)## around origin
##sinh(z +\frac{1}{z}) = \sum_{-infty}^\infty A_nz^n##
where
##A_n = \frac{1}{2\pi i} \oint \frac{sinh(z'+\frac{1}{z'})}{z'^{n+1}} d'##
Let c = unit circle, ##z'=e^{i \theta}##
## dz' = ie^{i\theta} d\theta##
using Euler relationships
## = \frac{1}{2\pi i} i \oint \frac{sinh(e^{i\theta}+e^{-i\theta}}{(e^{i\theta})^{n+1}} d\theta'##
Cancel out the ##e^{i\theta}## on top and bottom
## = \frac{1}{2\pi} \oint \frac{sinh(2cos\theta)}{e^{in\theta}} d\theta##
## = \frac{1}{2\pi} \int_0^{2\pi} sinh(2cos\theta) e^{-in\theta} d\theta##
##e^{-in\theta} = cos(n\theta)-isin(n\theta)##
Then I said that only the ## cos(n\theta) ## part mattered because I stated the bounds of the integral were from ##0 to 2\pi##
## = \frac{1}{2\pi} \int_0^{2\pi} sinh(2cos\theta) cos(n\theta) d\theta##
However, I've tried many ways of simplifying this and I can't get an answer. Any suggestions? I'm so stumped... :/
prove contour integral
##\int_0^{2\pi} \frac\{sin^2{\theta)}{a+bcos(\theta)} d\theta = \frac{2\pi}{b^2} [a-(a^2-b^2)^{frac{1}{2}}]##
## d\theta = \frac{-i dz}{z}##
## sin^2(\theta) = \frac{-1}{4}(z^2+\frac{1}{z^2}-2)##
## cos(\theta) = \frac{1}{2}(z+\frac{1}{z})##
Subst. all in and assuming unit circle:
## = -i \oint \frac{dz}{z} \frac{\frac{-1}{4}(z^2+\frac{1}{z^2}-2)}{a+ \frac{b}{2}(z+\frac{1}{z})} dz##
rearranging
## = \frac{i}{2} \oint \frac{dz}{z} \frac{(z^2+\frac{1}{z^2}-2)}{bz^2+2az+b} dz##
Then I solved this using the quadratic equations, so I had two roots (for the denominator)
I know I have to use residue theory, but I've never had to do it with something in the numerator. Is it still the same method? I'm confused...
Answers and Replies
Dick
26,263
619
Laurent series
where
rearranging
I don't get where you are going here. sinh(z) has a Taylor series around z=0. It's (e^z-e^(-z))/2. There are no negative powers of z at all.
d3nat
102
I mean, yah, I can solve it with a Taylor series, but I wasn't sure how to solve using a Laurent series, which is what the problem asks.
Dick
26,263
619
A Laurent series is just a Taylor series possibly includes term of negative degree. sinh(z) doesn't have any. The Taylor series is the same as the Laurent series.
d3nat
102
Ohhh. Well then, I feel dumb.
My professor made them out to be completely different, so I thought it was two different methods of solving.
Thanks!
Suggested for: Complex Analysis questions
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
