Complex Analysis
  • Thread starter jays
I have two questions on complex integration, and I do not know how to solve them. Please help if you can.
Thanks
1. Evaluate the following principal value integral using an appropriate contour.
Integration of (integral goes from 0 to infinity) : (x)^a-1/1-x^2,
0<a<1.
2.Using contour integration and calculus of residues, find the sum
Summation (going from 0 to infinity) 1/n^2 +a^2
Answers and Replies
shmoe
1,992
Hi, you'll get the most help if you provide whatever work you have, even if it doesn't appear to lead anywhere.
1) Have you seen a similar problem, but with no pole on the path of integration?
2) For series like this, a standard approach is to relate the sum to the poles of cot(Pi*z) multiplied by the appropriate function. Have you seen this method before and if so what happens when you try to apply it here?
Thanks
0<a<1.
Show some work first.
Here are some tips :
1) Do you know the theorems that you need to use the appropriate contour ?
2) This is an analytic multivalued function (because of the a exponent) so be sure to use the branch cut. Do you know about this ?
marlon
Related Threads on Complex Analysis
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
